Looking in from the cab, passenger side. Felt slight performance decrease when I went up to Tahoe, so hoping its just a minor fuel leak. Can't quite get at where the leak appears to be.
I believe that is the Return Fuel line from the Fuel Rail. Not sure if there is a gasket...or should be able to loosen and put red Thread sealant and tighten back down. Or tighten the flare fitting ontop.
Ive replaced a bunch of orings over the last year trying to isolate a leak. I think the one rally is thinking of is the icp sensor in the front at the base of the driver side head.
There's also a one on the underside of the hpop that's notorious for stripping out too. Dieselorings.com has a longer threaded replacement for a good price.
There's a good thread on expo that outlines a lot of good ideas for when your in there. I'll see if I can find it.
Get a UV dye kit at an auto parts store, add it to your oil or fuel, run the engine and shine the black light in the area of the leak. You will find it instantly.
I used this on all of the fuel fittings on the fuel bowl and at the heads when i was doing some maintenance a while back. It needs some time to set but it works pretty good as a fitting sealant for diesel. Also, follow that same line back in into the valley near the passenger side head. There is a clamp that holds that fuel line in place and the vibration of the motor can rub a pin hole in that line. You may want to also investigate the condition of that line around the clamp for preventative maintenance measures.
