Originally Posted by rexracer530
I'm not sure what normal temperature ranges are but Dashcommand Obd2 app showed EOT around 192 +- 10 degrees depending on speed and ECT 10-15 degrees higher than oil.
I'll also add that temperature seems to have no bearing on when comes on the off. It will come on when the engine is cold or warm. It never stays on though.
Rex, Assuming that you have good, clean, 15W40 like Delo, Rotella, or synthetic in there, here are the things I would check, in order:
1) use a quality gauge to check oil pressure at sensor port (this will verify that you have good pressure AND possibly show bad sensor
2)there is a bypass spring right there with the filter and is easy to check
3)possibility that the pick up tube is messed up
4)now that it is getting cooler out, the ebpv valve will be closing to speed warm up and may be sticking some(?)
FYI, poor quality or different viscosity oils can cause foaming and other oil related problems that can stop the engine in its tracks. Hope that helps.
