You can also wrap your downpipe with header wrap. I made soundproofing improvements to my entire floor, firewall, engine bay, doghouse, etc. and covered all near engine with flame proof foil type tape. After that, my up pipes were original and had typical leaks so replaced them with much better bellowed up pipes which I double wrapped with header wrap, baked them dry in oven, and coated with the silicon based spray on top coat paint. While I was at it, I did same to down pipe and added a Thermal Zero turbo blanket. Overall, much quieter, even with lots of other performance upgrades and aftermarket turbo wheel. A 7.3 is going to make noise, but the Hutch mod takes out the cackle sound by reducing air in your fuel rails too. Now, phone calls are possible with the windows closed!
