Old 07-02-2014, 04:00 PM   #1
alta825's Avatar
7.3L question - EGT temp range?
Didn't see much info listed for the 7.3, mostly just the 6.0 -
My '02 7.3L came with the Edge Tuner/Guage. What is an 'accepted' temp range for EGT's? Living in UT we have our fair share of Mtn passes etc... and I have been keeping it @ 55mph on the bigger highway climbs and the temps will approach @ 1100-1150, on mostly rolling terrain it'll be anywhere from 4-700*
What say y'all?
Thanks A Ton
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 07-02-2014, 06:10 PM   #2
TexGX's Avatar
Re: 7.3L question - EGT temp range?
Alta825,
I have been research this for my 2003 7.3. I am getting a ETG gauge installed soon so I can watch this. I am seeing 1200 as a good top limit. It seems moments over 1200 are ok if brief. Check the Powerstroke forums.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
TexGX is offline   Reply With Quote
Old 07-02-2014, 06:29 PM   #3
I'm with TexGX. I always keep it at 1200 or less, and honestly rarely let it hit 1200 at all. I try to keep it in the 1100-1150 range at most.
Old 07-02-2014, 07:12 PM   #4
alta825's Avatar
Perfect. Thanks Guys!
Old 07-02-2014, 07:32 PM   #5
Important to know / specify where the temp probe is located...there is a large difference between temps measured in the exhaust manifold and those taken in the downpipe. Measurement in the down pipe has cooled a great deal (I've read as much as several hundred degrees...though the split varies as temp varies).
Assuming probe is taken in the exhaust manifold my understanding is also roughly 1200* is max for sustained periods.
Here is a terrific site for diesel inquiry... http://www.thedieselstop.com/
rarrace is offline   Reply With Quote
