04-15-2009, 06:57 PM
7.3L vs. 6.0L
While I continue to hone my search for a SMB that meets my liking and browse between new and used, I see that Ford only now offeres (6.0L) but I have come across 7.3L (used) as well that were offered in the past. Can anyone tell me what the major differences between these two diesel engines (mileage, pros, cons, why Ford stopped making the 6.0l, etc...)? If you prefer one over the other that would help as well.
Many thanks.
04-15-2009, 08:19 PM
Re: 7.3L vs. 6.0L
I prefer the 7.3, but they are both detuned in the vans which I think makes power comparisons somewhat moot. In my case I wanted to find the 7.3L with an SMB 4x4, and although they exist (or so I've heard ) I couldn't find any during my search, so I wound up with the 6.0L because the SMB 4x4 was a must.
04-15-2009, 08:20 PM
Re: 7.3L vs. 6.0L
This guy's website is very informative and has all the info you need on these two motors.
http://powerstrokehelp.com/PSD_common/6vs7/1of6.asp
Rob
2006 SMB 4x4, EB-51, 6.0psd
04-23-2009, 09:38 AM
Re: 7.3L vs. 6.0L
The 7.3 has been around (in its various incarnations) for quite some time. Its a work horse. Its not without its issues, but nonetheless, its a solid and reliable platform. Right or wrong, I think its the better engine. Keep in mind I do not own a 6.0, but I have read unflattering stories about the early 6.0s on Dieselstop.com, etc. That said, I think you will find most 6.0 folks 'round these parts will tell you the 6.0 is a solid platform as well. However, the holy grail of SMBs is the 7.3 with the SMB 4x4 conversion. Those rare bearcats are reserved for only the coolest of the coolest of SMB owners.
05-20-2009, 09:12 AM
Re: 7.3L vs. 6.0L
Does anybody know if Ford has dealt with the 6.0 weak turbos on the 08 or 09 models?
Also, how many miles do you folks have on your 6.0 psd's?
09 E350 EB 6.0PSD SMB 4x4 kind of a 61 layout
02 F450 Flatbed 4x4 7.3 PSD
08 F150 5.4 ltr 4x4 Daily Driver
77 Orig Bronco in rebuild mode "uncut"
76 Orig Bronco rebuilt & driven weekly
71 Orig Bronco rebuilt & 4sale gots everything on it
Owned a jimmy once for about 6 months.
https://www.tropicalgardensofmaui.com
https://www.mauicabins.com
twitter @runnin6mpg
05-20-2009, 10:55 AM
Re: 7.3L vs. 6.0L
I only have about 60K on my 6.0.
The biggest issues with the turbo happen when the vehicle is either driven short distances (not gotten hot enough) or driven infrequently.
When driven every 7-10 days and always driven long enough to fully warmup (20+ miles) the turbos seem to be quite reliable. That issue also applies to 6.0's in pickups.
I had some problems with my van, including a turbo, 2 injectors and a host of transmission problems. The turbo issue was caused by parking the van between trips (common with RV's, and something I no longer do), the injectors failed in Canada running Canadian ULSD (listed on the pump as less than 50ppm - and inadequate lubrication for the injectors, now I run an additive), and the transmission problems were caused by the tech who worked on it. It seems quite happy now, and for the last 30K+ miles.
05-20-2009, 11:49 AM
Re: 7.3L vs. 6.0L
Just to elaborate a little on the turbo problems. In doing research and speaking to a Ford tech the problem does primarily lie with the VGT (variable geometry turbo). As touched on earlier when they are not driven up to temp frequently the vgt veins get condensate (read:rust) and soot built up on them and this restricts their movement. This cause poor turbo performance and can even cause failure.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
05-20-2009, 01:26 PM
Re: 7.3L vs. 6.0L
45K on my 2006 6.0PSD and no turbo problems as of yet. Its a daily driver. I always pre-warm for about 5 min before throttle up and I always watch the EGT before shutting down. The EGT is monitored while pulling stressful grades as well so if they get too high I pull over and let it cool down. I did get a questionable oil report that indicates a injector problem and will decide what to do after the next oil sample. I think the article that Rob supplied the link to sums up the 6.0 as best as anybody has. Here is more info on the basics, not so much the 6.0's turbo but much of this still applies...sorry I don't have the link:
Turbocharger Service is A Matter Of Common Sense.
By Rick Hehman and David Keiner Schwitzer U.S. Inc.
The day-to-day demands on today's heavy-duty turbocharger are extreme: temperatures exceeding 1200° F, severe pressure differentials, clearances measured in ten-thousandths an inch and wheel rotating speeds approaching 100,000 rpm. The turbocharger is designed to perform flawlessly in these extreme operating conditions. However, there are several factors affecting turbocharger service life that, if adhered to, will assure thousands of hours of successful turbo operation.
Turbocharger Basics
A quick refresher course in turbocharger basics is required prior to beginning a discussion on servicing the turbocharger. The internal combustion engine produces exhaust that is extremely hot and full of energy. Turbochargers harness that heat and energy by returning it to the engine's combustion cycle.
Turbos turn waste into work. The engine exhaust drives a turbine wheel, which is connected via a common shaft to a compressor wheel, which compresses air and pumps it directly into the engine's intake system. The result is a denser charge of air resulting in more efficient combustion, which creates a cleaner exhaust (reduced emissions) and more useable power.
The turbine wheel shaft rotates in a housing located between the compressor and turbine sides which contains the turbo's vital bearing system which, along with the engine's oil supply, lubricates and cools the rapidly rotating wheel and shaft assembly. There are several different types of bearing systems used by turbo manufacturers today, but most are free-floating journal bearings which rotate approximately one-third the speed of the shaft on a thin film of oil.
Causes Of Turbocharger Failures
Approximately 40% of all turbocharger failures are oil-related. Contaminated or dirty oil leads to bearing scratching and scoring which cause excessive bearing wear and premature bearing failure. Another oil-related turbocharger failure is lack of lubrication. As mentioned earlier, the turbo runs at very high speeds. Without full oil pressure to the turbocharger bearings, even a momentary loss of oil pressure can quickly cause overheating and destroy the bearing system.
Lack of lubrication results not only from low oil pressure, but also from kinks and/or clogs in the oil inlet line. Occasionally, gasket sealant used between the oil inlet hose and the bearing housing seeps and clogs the oil passages.
Another cause of turbocharger failures is inlet restrictions from plugged air cleaners, collapsing hose connections or undersized air pipes. These restrictions reduce the air supply to the turbo and ultimately to the engine resulting in excessive exhaust temperatures leading to turbine housing cracking and scaling or even turbine wheel failures.
Inlet restrictions also can produce a vacuum inside the compressor. This can cause over speed conditions in the turbo which can lead to premature bearing failure or even make a compressor wheel burst. This vacuum inside the compressor also can cause oil leakage into the compressor.
The turbo's oil seals depend upon a positive air pressure inside the compressor and turbine to "push" the oil inside the bearing housing and keep oil from seeping into the outer housings. In an inlet restriction situation, the vacuum wants to "pull" the oil past the oil seals. Prolonged oil leakage into the compressor can lead to oil seal damage and excessive engine smoking.
Prolonged engine idling also can cause turbocharger oil seal failure, this time on the turbine side. Continued idling causes the turbo to rotate without producing boost. Consequently, a vacuum condition on the turbine side tries to "pull" oil past the turbine-side oil seal and into the turbine housing.
Over-fueling also can lead to premature turbo failure by producing excessive exhaust temperatures which can cause turbine housing scaling and cracking. As the turbine housing continues to deteriorate from the excessive heat, pieces of the housing can crack off and cause turbine wheel failure.
Hot engine shutdown also can lead to turbocharger oil leakage by causing the oil to coke up inside the oil drain and forcing the oil out the turbine and compressor seals. A clogged or collapsed oil outlet hose also can cause oil to leak.
Another common cause of turbo failures is foreign object damage to either the compressor or turbine wheels. A rapidly rotating wheel quickly disintegrates when a foreign body tries to pass through the wheel's blades. This type of turbine wheel damage is the result of pieces of burned or broken valves and combustion cups passing through the exhaust system. Other turbine damage is due to casting flash that may break out of the manifolds and ports.
Occasionally improperly installed gaskets will allow pieces of the gasket to overhang a port and break off into the exhaust system. Damage caused by nuts and washers that are dropped into the exhaust system is also very frequent. Scuffed and broken pistons often find their way out of the engine and into the turbocharger turbine wheel.
Compressor wheel breakage also can occur from foreign object material although not as frequently as turbine wheel damage. Sometimes pieces of the air cleaner will break loose and go through the compressor. There also have been instances where hose connections fail and pieces of rubber or wire reinforcing from the hose get into the compressor wheel. Again, carelessness in allowing nuts, bolts, washers, rocks, rags and even screwdrivers to get into the intake systems will cause compressor wheel failures.
Preventing Turbo Failures
After examining the various causes of turbocharger failures, common-sense can prevent such failures in the future. Keep the engine full of clean oil to the engine manufacturer's specifications. Also keep the air filter clean and unrestricted. The duct work from the air cleaner to the turbocharger compressor should be free from holes and all connections should be tight to prevent leaks which could allow dirt and debris to enter the turbocharger.
Warm up the engine for two to five minutes prior to throttling up the engine. This procedure assures proper oil pressure to the turbocharger prior to operation under load conditions. Let the engine idle for approximately two minutes prior to engine shut down. This cool-down period prevents oil coking and oil varnishing on the turbine wheel and shaft. Varnishing is a build up of oil on the shaft which increases clearances and decreases the flow of oil to cool and lubricate the shaft.
Correct Turbocharger Installation And Servicing
While this may sound obvious, make sure that the turbo used is correct for the engine application. Turbochargers are precisely matched to the application and misapplication can lead to turbo failure and/or severe engine damage.
Inspect the intake and exhaust systems leading to and from the turbocharger to ensure absence of all foreign material including burrs, nuts, bolts, washers, rags and loose lining fragments. Be thorough-even small particles can cause severe compressor or turbine damage if inducted during high speed operation.
Use new and approved gaskets at the various air, oil and exhaust connections to the turbocharger. Do not use any type of sealing or jointing compounds at oil inlet or outlet flange connectors. Check manifold studs and nuts and check for obvious signs of manifold deterioration (cracking, scaling, etc.). Use a high temperature antiseize compound (such as Fel-Pro C5A) on all threaded fasteners connected to the turbocharger.
Limit drain port tilt to 20 degrees from bottom center in either direction. Tilting in excess of this amount can create a Low idle leakage tendency at both the turbine and compressor seals.
Fill the oil inlet port to overflowing with clean engine oil before connecting the oil feed hose to the turbocharger. Then, prior to mounting the turbo on the engine, spin the compressor wheel by hand to make sure it spins freely.
If the clamp tabs or V-bands are loosened for angular orientation of the compressor cover or turbine housing, be certain that the mating flanges are tightly reseated, and that the fasteners are retightened to the correct torque levels. Complete the orientation of the cover and housing before making any rigid connections to the compressor inlet and outlet, or to the turbine outlet. Then, make certain that all ducting aligns closely with the turbocharger; this will minimize the external stresses acting on the unit. Before connecting the oil drain hose, crank the engine without firing until a steady stream of oil flows from the drain port. Make sure the oil drain hose is not blocked.
Operate the engine at low idle for at least three minutes after completing the installation of any turbocharger. This will prevent oil starvation damage to the bearing systems, and will tend to purge any residual contaminants from the bearing housing prior to unit acceleration.
05-20-2009, 01:32 PM
Re: 7.3L vs. 6.0L
That is more for a standard turbo, not specific to the VGT turbo on the 6.0. A fixed vane turbo doesn't have the issues with rust or soot causing the vanes to stick - the main problems with 6.0 VGT turbo.
05-20-2009, 01:53 PM
Re: 7.3L vs. 6.0L
Scatter, where are you? I think you might have something to add to this 6.0 turbo business.
