Old 03-07-2018, 01:59 PM   #1
97 7.3 E350 Coolant leak passenger side
I have a 7.3 Powerstroke and I just noticed after I parked in my driveway last night that there was coolant leaking from the front passenger side of the van. Took a quick look (it was raining) and couldn't tell where it was coming from but it looked like it was only a few inches up. Does this sound like a new water pump is needed? Or are the symptoms something else?
rexracer530 is offline   Reply With Quote
Old 03-07-2018, 09:11 PM   #2
MSD
MSD's Avatar
It could the water pump but that should be more dead center than to either side... check your lower radiator hose, follow it up from the radiator to the engine my clamp has come lose once and it also cracked once which caused a similar leak. Wish I could be of more help...
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 03-08-2018, 12:26 AM   #3
TomsBeast's Avatar
The 7.3's oil cooler is on the driver's side, as are the coolant tank and bypass hoses. I think the lower radiator hose connects to the radiator on the passenger side. A thermostat housing seal leak and upper rad hose will dribble down under the front engine casting, about front center. so will a water pump seal leak. The fan will push the drips all over the place. Best to hose it off with clear water, fire it up and crawl underneath and look for colored water dripping.
Old 03-08-2018, 06:39 AM   #4
Bbasso's Avatar
I agree clean it up first then you should be able to rent a pressure tester for your coolant system. With your van off and cold hook up the pressure system checker and it should reveal any leaks you have with ease.
Rob.
Current:
And had three other E350s...
Old 03-08-2018, 11:26 AM   #5
Try this or something similar
https://www.amazon.com/Mastercool-53...ine+oil+uv+dye
Old 03-09-2018, 04:57 AM   #6
Originally Posted by arctictraveller View Post
That's a nice little inexpensive kit---good find!
Tags
7.3 coolant leak
« Lpg | 6.0L issue »
