Old 08-06-2010, 04:28 PM   #1
AC Compressor suggestions?
I have a 1992 SMB with Starcool AC in back. My mechanic said the system is full, but the compressor appears to be bad because there is only a 75lb differential on the AC system. If I am going to replace to compressor, would it be best to install a larger one to compensate for having two condensors (the original van and the Starcool)?
Also, the Starcool system seems to have an electronically driven auxilary fan which is very loud. Any suggestions on how to minimize that noise? My guess is that it may be touching a shroud, which should be easy to fix, but if someone had similar problems, I would love to learn from them.
Thanks for any insight.
1992 E-250 extended SMB, style 42 layout, penthouse top, 2 burner stove, Starcool, Suburban furnace, fridge, 35Gal water
OldRedFord is offline   Reply With Quote
