Originally Posted by Mahukaawe
So you can use other oil/syn in the amsoil system?
Do places like Oil Can Henrys carry amsoil products? Proably not.
Who sells the filters/ oil and is it best to just carry them in the van
so you always have a back up?
Ours has the system but we are new to it. Figured it would be a good add for a van like this that will be putting on a lot of miles.
Thats after reading the horror stories of the earlier installs.
Yes you can use other oil, synthetic or not.
>Who sells the filters/ oil? Do places like Oil Can Henrys carry amsoil products?
It would probably be best to spend 20 bucks a year and become your own dealer especially if you're a diesel owner. I have found several independent local parts stores that carry AMSOIL products.
One of the best things you can do for a diesel is to filter the oil using a high grade twin filter system but I found a difference when using the synthetic oil as well. You should follow Fords recommendations and use Ford products during the break in period.
>Is it best to just carry them in the van so you always have a back up?
I always carry extra filters in the van. If you loose oil you can go back with regular oil and then switch back after you return home. I've also been told it's OK to top off AMSOIL with standard motor oil as an emergency to get you out of an area. AMSOIL sells a product to help clean out the old oil before you dump it. If it happens to me I will do a full change if possible by just adding something like Mobile-1 synthetic and run it for 5K then switch back to AMSOIL. At least it will keep the cost down.
>That’s after reading the horror stories of the earlier installs.
Yes it was horrible but so far I have found no engine problems that can be contributed to the mistake. Time will tell.
AMSOIL will tell you that you're able to run for longer mileage periods using their products and procedures. I plan to keep to Ford requirements until the vehicle warrantee is complete.
