Originally Posted by Skywagon
On long grades or prolonged slow 4 wheeling, my transmission temps top out at about 230- 233 deg. It doesn't matter if it's Moab in Summer or Donner Pass in January. The ambient OAT doesn't seem to have anything to do with it. One would THINK it should, but it doesn't.
What it DOES do though, is to return to normal temps (180-185 deg. for mine) more quickly in the cooler OATs.
Bill
That would tend to make me think that the sensor tops out, or the radiator-stack fan kicks up speed, not that the transmission stops producing more heat than the cooler can dissipate...
The fan has a number of speeds that it can engage at though its viscous coupling, and kicks them up as a function of EOT, ECT, and Transmission temp. You can even put in a fan clutch with greater engagement at the slow-speeds (sold for pickups using plows, which block airflow to the radiator).
The reason we put the vents into out engine compartment was to allow the air the fan pushes to go somewhere, making it more effective at the lower speeds. Also helps the engine compartment cool off after getting toasty w/o popping the hood.
Even if the peak temperature the fluid reaches is the same, the less time it spends there, the better. Do a search online for 'transmission fluid temperature lifetime' and there are any number of graphs of service-life vs temperature. Getting to 230+ really really impacts this.
-e
