My first visit to a junkyard since college. Fun stuff!
Thanks for the advice. I was too late for this one. The rear end of the van was up on blocks and the axle was gone.
But they had lots of wrecked ford vans and lots of them had full float axles
Brakes:
I only saw drums but I am getting the impression that if I switch to an axle with discs, I will have to do some fairly extensive brake work. Something to do with proportioning valve and possible replacing the master cylinder?) But I've also seen discussions about changing from drum to disc. I think I'm fine with either one.
Axles:
The two axles I looked at closely (they were closing) were both full float but, unlike the previous full float I looked at, they did not have "D60" or "60" or "70" stamped into the casing. They were both 10 bolt. What does that mean? The markings on the casing were no use as far as I can tell "248-001", "304", "AC", "NC4", "47510".
There were both 350's and club wagons with the full floats. As long as it is a full float, original equipment on a Ford van, late 1990s, and has the ABS sensor port in the differential housing, do I care which one I get? All I am after is higher weight capacity, limited slip, and possibly a locker later.
I'll ask around in other forums but does anyone know what brand full float axles were put in ford vans (350s and club wagons) in the late 1990s?
If there is a wrong one to buy, I'm certain I'll get it.
I appreciate all the advice so far. This is like looking for the holy grail....in mud.
Tom
