Old 09-18-2010, 09:59 PM   #1
Silver350's Avatar
Basic car math everybody should know
Want to figure out why your engine seems like such a dog after you bolted on those 35's? Wonder why you cant' pull O/D all of a sudden? Get these numbers and you will have the answer.
Find your:
1) Tire Revolutions per Mile (20,800 / tire diameter = Tire revs per mile.)
2) Transmission final drive (usually 1.0 in direct or .71 in O/D)
3) Final drive (3.7, 4.1, 4.56, etc.)
Now you can find the answer:
Transmission final drive x Tire RPM x Final drive = Engine RPM @ 60 MPH
Engine RPM / 60 x your desired speed = Engine RPm @ your speed
Old 10-06-2010, 11:28 AM   #2
ScotFree's Avatar
Re: Basic car math everybody should know
Good Info, Thanks
'08 E350 SD EB Cargo 6.0
Bought New 5/2010
Quad Van 4x4
Rudimentary DIY Camper
ScotFree is offline   Reply With Quote
Old 10-07-2010, 09:49 AM   #3
People often want to lift a rig and put on big tires and then get back to stock RPM with a ring and pinion change. Whats often forgoten is the extra weight and the extra wind resistance due to the additional height. These add up to the need to run a higher RMP than stock to be in the powerband and to keep it from hunting in and out of high gear. I have never heard anybody say they wish they had gone with higher gears but often hear "I should have gone lower."
Stumpalump is offline   Reply With Quote
