Old 02-12-2015, 10:45 PM   #11
Re: Best Fuel Pump for Ford 5.8L ?
Push harder?
There's probably gunk jammed up inside the fitting keeping the spring from releasing. Might need to blast it out with some good cleaning oil.
Last time I did my fuel filter, I had to tap the release tool in with a wrench.
Old 02-13-2015, 06:05 AM   #12
E350's Avatar
No fooling around now, I am getting the big guns:
