Old 05-17-2014, 02:07 PM   #1
woodbee's Avatar
Bolts around oil pan torque
I would like to check the torque on the bolts around the oil pan. 2009 E-350 with 6.0 engine. Does anyone know right off hand?
Thanks,
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 05-17-2014, 02:38 PM   #2
Tapatio's Avatar
Re: Bolts around oil pan torque
Woody
I couldn't find specific torque values for the pan bolts, check this link, there are some standard torque recommendations based on bolt size.
http://www.powerstrokediesel.com/docs/EF_456.pdf
Callsign KK6GIY
Old 05-17-2014, 04:15 PM   #3
woodbee's Avatar
Thanks Ron, I think I can figure it out with the chart.
Woody
Old 05-17-2014, 07:21 PM   #4
I just did this. 14 ft lbs sounds right. It's not nearly as much as you would think.
Old 05-18-2014, 04:28 AM   #5
I would agree with this---I've heard or read somewhere 15 ft/lbs. Much more and you could warp the pan etc.
Babe
Babe
Rufus
LARufus
