Old 06-15-2011, 09:40 PM   #1
stikine's Avatar
Bottom Fuel Filter R/R on 6.0L Advice
Just checking to see if I'm missing something when changing my bottom or chassis mounted fuel filter. I open the fuel/water drain for 25 seconds as per the shop manual, then unscrew the housing but the diesel fuel just continues to shower out at at a pretty good clip until I get the new filter in and my new O-ring on the housing & screwed back on.
Just checking if this is normal, realize being down low and mounted on the chassis doesn't help but what a pain & get lot of diesel on my skin even with gloves - any suggestions welcome.
2007 SMB White 4x4 RB50 6.0l Diesel PH, Toyo 295/70/17 M/T E
https://www.ecotonephoto.com/
stikine is offline   Reply With Quote
Old 06-15-2011, 11:00 PM   #2
Re: Bottom Fuel Filter R/R on 6.0L Advice
Mine drained for a long time. I opened up the drain and let it dribble for about 20 minutes or so. Normal I believe.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 06-16-2011, 07:34 AM   #3
stikine's Avatar
OK, I will let it drain longer next time, amazing how much diesel does drain out, at least half a gallon but good to know it will finally quit. Thanks!
Old 06-16-2011, 08:16 AM   #4
pjpvi's Avatar
Try opening the drain valve then "crack" the seal by loosening the filter housing a little to let some air in. I think I did that last time and it drained out much more quickly.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 06-16-2011, 12:24 PM   #5
I've never had more than a cup or two drain out. I've never had a half gallon or more drain when changing the chassis mounted fuel filter. However, I've also always changed it with the van at a bit of an angle (rear higher than the front) due to our driveway slope.
Old 06-17-2011, 10:18 AM   #6
etbadger's Avatar
I have only had about the volume of fuel in the filter housing drain out, and speed it up, as above, by loosening the housing after cracking the drain.
I do change the filter on a rather low tank as I don't want to siphon fuel out of the tank (not sure if there is a check-valve, but would rather not find out to the negative. Seems likely there would be, but also something that could fail without any other side-effects or warning.
-e
https://www.badgertrek.com - Badgers on Wheels
etbadger is offline   Reply With Quote
Old 06-17-2011, 06:28 PM   #7
SheepShagger's Avatar
Tank level.
I have no idea why, but when my tank is full, I've turned it off after draining 2~3gals from the filter, and gave up.
If I change that filter on an 1/4 or less tank, only 1/2 cup will come out before it stops.
I change my filters evry other oil change, so I've had plenty of times to play with this. Now I never bother touching it unless the tank is almost empty.
Old 06-18-2011, 08:23 PM   #8
I changed my fuel filters today and took notice of the drain on the chassis mounted filter. I opened the drain while I did the top filter and it still continued to drain at the same rate until I started to unscrew the cap on the bottom of the housing. Once air entered the housing from the loosened cap, it stopped the siphon I believe. No mess at all.
Desert Solitaire
2003 7.3L EB 4x4
Old 07-01-2011, 09:49 AM   #9
What is the milliage interval for both fuel filter change?
Ketcham is offline   Reply With Quote
Old 07-01-2011, 02:26 PM   #10
I believe Ford recommends every 15k miles.
