Old 04-13-2013, 12:06 PM   #1
Zeta's Avatar
Burned by Espar
Sooooo, I'm camping at Page Springs in Oregon where it got down in the mid 20's overnight. I thought I would be smart and run the Espar water heater to warm the engine so it would start easier. I ran it for over 30 min, and sure enough the oil temp rose to nearly 140F. It wouldn't start!
Cue freakout.
Calm. I noticed however the oil temp went down the more I cranked. Turns out the glowplugs don't operate if it's over 131F, so it thought the engine was warm, but only the oil around the sensor was, so no glowplugs even though it needed them to start. Yikes.
Started instantly this morning...
Z
'06 RB50 SMB Diesel
http://www.tomsinclair.net
Old 04-13-2013, 01:24 PM   #2
Re: Burned by Espar
Do you have a clue why it did that? I can run mine for 2 hours with no problems. Maybe the Espar didn't cycle off. Could the Espar heat sensor not shut down the unit and it just continued to run causing an overheat issue?
Old 04-13-2013, 04:52 PM   #3
Jeffrey's Avatar
Re: Burned by Espar
Just run the furnace next time.
Old 04-13-2013, 05:28 PM   #4
Re: Burned by Espar
The furnace won't warm the engine.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 04-13-2013, 05:30 PM   #5
Re: Burned by Espar
Well it might if you pull the dog house off
Old 04-14-2013, 12:32 AM   #6
Zeta's Avatar
Burned by Espar
I think running the Espar for only 30 min made the engine computer think the engine was over 131F, when it was, mostly, cold and needed the glowplugs activated. It acted like a diesel engine with faulty glowplugs, but finally started.
Running the Espar for two hours would warm the engine much more fully.
Z
'06 RB50 SMB Diesel
Old 04-14-2013, 01:07 AM   #7
Re: Burned by Espar
I've run my Hydronic several times in that kind of weather and have never had that happen. So you think the short time did it? I've done similar times in upper 20's with no problems.
Old 04-14-2013, 11:51 AM   #8
Re: Burned by Espar
Your preheating depends on how your hydronic system is plumbed. Mine is currently plumbed so that it doesn't actually heat the entire engine just the heater core. If my hydronic system has been preheating for a while, the temp gauge will indicate somewhere in the 'warm' range but then will drop down as the engine is started.
I would ideally like to re-plumb mine so that it actually pre-heats the entire engine. Badgertrek did this with good results. http://www.badgertrek.com/sportsmobile/appliances.shtml
Would be interesting to know if Badgertrek has experienced the same problems as Z
'04 EB-350 6.0 PSD SMB 4x4, PH, EB-50, Aluminess F/R
dparkwy is offline   Reply With Quote
Old 04-14-2013, 01:06 PM   #9
Gnarvan's Avatar
Re: Burned by Espar
Where is the temp sensor probe on a 6.0 located?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 04-14-2013, 06:01 PM   #10
Tapatio's Avatar
Re: Burned by Espar
I fired up the Hydronic today and let it run until it turned itself off. Scangauge showed 155f EWT, 133f EOT. Engine started. No idea what that means but there you go.
Callsign KK6GIY
LiamMobile
Shyll
Vanzilla
Steve C
