Originally Posted by rallypanam
Odd.
Do delaminating tanks jack up fuel pumps as well?
Yes, at least on the 7.3L PSD OEM fuel pump, there is a nonserviceable internal screen in the fuel pump which can clog up. Here is the internal dissection thread of the 7.3L PSD OEM stock fuel pump by Pete username F250_ on ford-trucks.com:
http://www.ford-trucks.com/forums/12...-and-pics.html
Pete's photos of the inside of the pump are attached.
But I don't know where your gasser fuel pump is located. Is it on the frame rail like my 7.3 or is it in the fuel tank like my Bronco?
But prove me wrong. I am just trying to help, but you have a 5.4L gasser on which I have no experience, so I could very well be wrong. But here's the deal, it really couldn't hurt you to look at your fuel filter and determine if it is clean or not.
I mean can't we all agree, that a filter is meant to restrict. And a dirty filter will generally restrict too much reducing fuel pressure and volume.
And that could lead to a fuel pump (and even worse - injectors) which is starved from fuel which can cause heat build up, which, at the very least, can hurt engine performance and maybe pump longetivity.
