Re: can you drive on a bad 6.0 PSD injector?
Great! Inquiring minds want to know. You are way ahead of avoiding this problem by having a fuel pressure guage. The reason I (later) knew I had fuel starvation was because I could only drive half way up a mountain (i.e., greater engine load drinks more fuel than the clogged system could deliver), then stop, then wait (apparently for the fuel bowl to replenish) then start up the rest of the way. I was too stubbern to stop in the middle of nowhere to get into diagnosing the problem. So unfortunately for me it went from diagnosis to forensic analysis.
