John,
Maybe you need a more open air intake to go with your open exhaust?
I tried that Herb. Here is that project;
viewtopic.php?f=39&t=11277
I did think that once I got that air intake installed that it may balance thing out but it didn't help.
Originally Posted by JoeH
This is really interesting. Could it be that the decrease in backpressure on the turbo actually decreases mileage by impacting fuel/air combustion efficiency? You would think that it would be the opposite and that allowing the engine more breathability it would be more efficient but instead it's the exact opposite.
This is what all the info I found lead me to believe. Even if the MPG's stayed the same and the power went up, I would not have been surprised. But for the milage to drop like that? The only explanation I got from a few diesel shops was "yeah, sometimes that happens". What?
Viejo, I do have a tuner with custom tunes. The guys at Innovative Diesel (their the one that did the tunes on my SCT Tuner) suggested that I try their Supper Street Tune. They said sometimes this can bring up the milage if you're easy on the gas pedal. I did drive around for a few months on the standard Street Tune but that didn't help (it didn't make things worse either). So I thought that the Supper Street Tune wouldn't be the right fix.
I also know that getting better exhaust flow is not only about bigger pipe. Sometimes this can cause turbulence that can cause more back pressure. But because my EGT's are lower with my custom down pipe, I have to believe that the flow is better.
And not enough back pressure can cause a loss of low end power. Which did not happen in my case. I absolutely have less power now that the stock down pipe and cat are back. But the EGT's are only slightly up.
