Old 08-28-2012, 05:47 AM   #11
Re: Change Ford 5R110 Tow/Haul to Overdrive On/Off ?
Originally Posted by BajaSportsmobile
Something does not make sense. It is my understanding that the 5R110 (TorqShift) has only Tow/Haul mode and no overdrive cancel switch and the E4OD/4R100 did not have a tow/haul mode, it only had an overdrive cancel switch.
As I understand it
5R110
V10: Tow/Haul on-off
Diesel: OD on-off
4R100
V10: OD on-off
Diesel: OD on-off
Old 08-28-2012, 12:15 PM   #12
Ultrasport12's Avatar
That is correct...
...Jamie
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 09-11-2012, 06:58 PM   #13
Hey Guys I had 5 star tuning program my transmission to stay in fourth gear when tow haul is engaged. Works fantastic, I love it. I use it like OD on and off. If I see a large hill ahead I can push the button and gear down to fourth, roll up the hill, then push the button and I'm back in fifth gear. My tranny still shifts stock when cruise control is engaged. I also had Mike keep my torque converter locked up most all the time, no more half shifts.
Jim
2006 Quigley 4x4 RV
Old 09-11-2012, 10:33 PM   #14
So you changed the OD on/off switch to a tow haul switch?
Old 09-12-2012, 09:09 PM   #15
No my unit has a tow haul switch that now when engaged stays in 4th gear with the torque converter locked up most of the time. Fifth gear or OD when Tow Haul is engaged seems silly to me. If I'm rolling down an easy grade towing or loaded I'll leave the unit out of Tow Haul to maximize fuel economy. If the unit is working uphill or downhill I'll leave it in Tow Haul and utilize 1-4th gear.
Jim
