Old 02-07-2016, 11:35 PM   #21
geoffff's Avatar
Originally Posted by BajaSportsmobile View Post
P.s. While you've got those shocks off, why don't you get some good ones.
Well, I guess that's a whole other topic I'm using these OMEs because they're sold by Sportsmobile. And I've already have a spare set of new ones queued up I got cheap from someone.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 02-10-2016, 12:22 AM   #22
geoffff's Avatar
I finally ended up going with the stone-shield-removal option rather than cutting a new hole in my crossmember. I didn't trust my engineering decisions, and decided I had more confidence in modifying the shock itself. Cutting the metal shield off the shock was easy, and I replaced it with a pretty yellow boot I'll give it test next week.
-- Geoff
Old 02-10-2016, 07:19 AM   #23
Nicely done. Simple solution and it should work just fine for you.
ert01 is offline   Reply With Quote
Old 02-18-2016, 10:21 AM   #24
schluchtenflitzer's Avatar
To late but maybe it will help others. I had the same problem but after loose the tank a bit i was able to push it to the middle about half inch. Than i fix it again. This works perfect since 10000mls rough roads in Africa
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 02-18-2016, 10:11 PM   #25
geoffff's Avatar
That's a good idea, thanks. I wasn't sure if this was possible, but I'll give it a try the next time I replace my shocks.
-- Geoff
