Old 10-15-2018, 12:34 PM   #1
larrie's Avatar
Coolant reuse
A month or so ago I drained the coolant and replaced the hose assembly on the 5.4 in the van. Put all new coolant in the system. The coolant that came out of the radiator is sitting in a couple of milk jugs in the garage. Is it safe to reuse the used coolant or should I recycle it?
Old 10-15-2018, 12:50 PM   #2
shenrie's Avatar
id reuse it providing it wasn't contaminated.
Old 10-15-2018, 01:41 PM   #3
I'd reuse but I'd also strain it and examine what is strained out.
SMB123 is offline   Reply With Quote
Old 10-15-2018, 03:15 PM   #4
Bbasso's Avatar
I'd strain it with a clean magnet. If clean, I would reuse.
Be sure to check SCA, hydrometer and use the testing strips too
Rob.
Current:
And had three other E350s...
Old 10-15-2018, 05:30 PM   #5
LenS's Avatar
If it has about 100k miles on it recycle it.
Len & Joanne
The Green TARDIS
Old 11-01-2018, 01:25 PM   #6
Negative....use fresh coolant do not recycle.
Quigley-76 is offline   Reply With Quote
Old 11-03-2018, 07:21 AM   #7
Coolant have additives that wear out if I remember right. There are a lot of new choices out there now. Not worth saving $30.
Brianf7028 is offline   Reply With Quote
