Lifters can clatter, but I never heard one knock. That's usually something more serious like a rod or main bearing. Either one of these can be caused by low oil pressure, has that been checked with a mechanical gauge? If a lifter is bad, the cam will need to be checked too. If your mechanic is certain its a rocker arm, will he gaurintee it will fix the problem? Before sinking a ton of money into that engine, consider the cost of a replacement, low mile used one. These motors are known to go hundreds of thousands of trouble free miles, but once in a while one goes South prematurely, so I wouldn't be afraid of a used one. I'd get another opinion. Best of luck
