Old 03-27-2012, 05:03 PM   #21
BIGVANS's Avatar
Re: Diff oil of choice
Sorry about that, the dif info is in my listed in my signature so I didn’t want fill the post with duplicate information.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 03-28-2012, 05:19 AM   #22
ANZAC's Avatar
Looks like my brain filters sigs out!
Sportsmobile-less.
Old 03-28-2012, 04:22 PM   #23
BIGVANS's Avatar
I can totally understand that!
As far as the oil, I have no real loyalty to Amsoil. I got a great deal on a case so I tried it. I can say that when I check the dipstick (ARB Dif Cover) the oil still looks and smells like new even after 52,000 miles. Most of the general 4x4 shops I have asked say they just use the cheapest dif oil they can find because they have the covers off all the time, but If you are going to use the oil for more mileage, use synthetic.
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 03-28-2012, 04:44 PM   #24
ANZAC's Avatar
You guys should really read the info on the LE oil. Dino oil but SAE 110.... due to changes in SAE90 rating (from when the vehicles were made). Works great. I posted info in another thread. These guys make oil that is used in a lot of industrial/construction applications.
Sportsmobile-less.
