So I've been hearing a clunk when coming to a stop and then sometimes when accelerating from a stop.
Ive searched this forum quite a bit looking for driveline info, slip yoke, driveshaft splines etc with not much luck..
Ive also looked at another enthusiast forum and there is a ton of info that covers ford pickup trucks but not much that shows our 1 piece aluminum drive line, and if the output from the trans has the same spline lube issue that the trucks have. It would be a cheap and fairly easy fix.
Is it as simple as just unbolting the four bolts on the rear of the driveline and pulling the driveshaft from the rear. Is this a slip-yoke type system. Will tranny fluid come out if I pull this.
Sorry for being so uninformed but I haven't pulled one of these from a van before.
Ive got the lube and im ready to go
just dont know where to put it
