Originally Posted by E350
Chance: I definitely stand corrected. My narrow experience is with the 7.3L and although it is turbocharged, it is my understanding that it has a narrow max torque band in the low rpm range which Dave Whitmer describes.
E350, there is probably some of that to it because older engines didn't breath as efficiently, but I'd bet that there is more to it than even that.
I haven't followed Dave Whitmer like you have, but from the link you posted it seems that he is very interested in fuel economy, to the point of modifying his truck to improve MPGs. And that means improving the truck's aerodynamics with front air dam and possibly lowering by 4 inches (not sure that's what is meant by slamming but truck looks lower than normal) and who knows what else he does in typical driving which may approach hyper-miling techniques.
Anyway, if he drives conservatively at 60 to 70 MPH with an "aero" truck, he's normal power requirements are probably much lower (as in lower HP) than what most of us would see with a huge tall and heavy van that may have a raised roof, air conditioner hanging on top, awning on side, and so on. My point is that because he requires so much less power than many vans on this forum, the only way he can get BMEP (brake mean effective pressure) up high enough to be very efficient is to run the engine at super low RPMs. However, the same probably wouldn't apply to a heavy and tall non-aero van. Think about it, if he's almost lugging the engine at 60 to 70 MPH with an aero truck that is probably lighter too, what would happen if that same drivetrain was replicated in a van requiring twice as much power?
Obviously the answer is that it can't happen, right? The engine would require a downshift to pull the greater HP load requirements of a camper van versus aero truck.
In my opinion his solution is to make the best out of a bad situation. His engine is simply too big to optimize fuel economy when running empty at 60 to 70 MPH. If his truck had a 3.0L 4-cylinder PowerStroke like those sold in South America, or one of the new 3.2L I5 PowerStroke like will be used in the new Transit, the engine wouldn't have to be run so darn slow in order to increase BMEP. Either of these smaller engines could run twice as high RPM and still have higher BMEP.
If you are going to apply his ideas to a larger, less aero, and probably heavier van, and particularly if towing, you really need to consider that the requirements on the engine will be much different. If so, his gearing won't work for you, or at least give you same results.
