Old 08-16-2013, 02:05 PM   #1
haywoodphotomaccom's Avatar
Engine stalled a few minutes ago......
Driving up Bishop Creek Canyon right now and the engine started to stutter and then stall on a steep grade. Engine code P0301 if showing on the gauge. Stopped for lunch at the top on the mountain and will try to limp to town.
Read what the code means on the net just now. Any advise from the group before I find a mechanic in town?
Also been showing P0191 on and off for a few weeks.
Not a great first day of vacation so far.....
Brent
2006 Quigley V-10 (Sold)
Old 08-16-2013, 03:01 PM   #2
Zeta's Avatar
Re: Engine stalled a few minutes ago......
P0301-Missing on #1 cylinder
P0191-Fuel rail sensor
Sounds like you have a fuel pressure issue. Pump?
Is it hot? Vaporlock?
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 08-16-2013, 03:06 PM   #3
No, no that can't be - only the 6.0's fail when in a bad location.
Seriously, I've been there and you have my best wishes for a good outcome.
Old 08-16-2013, 03:21 PM   #4
Most likely low fuel pressure. Maybe a plugged fuel filter? I would be very surprised if your fuel pump itself is the problem.
Old 08-16-2013, 04:25 PM   #5
No help anywhere in Bishop. Everyone is booked solid with buisness. Going to see if I can limp around for the week and have it fixed at home. Off for a beer now.....
Brent
Old 08-16-2013, 04:36 PM   #6
Roonie's Avatar
try fuel filter. It is cheap and easy to replace. Mine was located right under the drivers door near the frame rail. Most auto parts stores carry them or quick lube oil change places.
Old 08-16-2013, 04:49 PM   #7
Jeffrey's Avatar
I wish I knew enough about the gasser to help you, Brent. Oh well, more time to photograph...
Old 08-16-2013, 06:02 PM   #8
When your driving around town does the engine seam to be missing? it could be a bad
plug or more likely the coil on cap went bad. I would start with the fuel filter replacement.
Good luck Dave
unimogdave is offline   Reply With Quote
Old 08-16-2013, 09:16 PM   #9
2 seconds of reception.....happening even after a long hill doing 35-45 mph.
Brent
Old 08-17-2013, 02:11 PM   #10
Any updates Brent?
Jnlola
jnlola
TBD
thatsandrea
