Old 08-09-2019, 12:11 PM   #1
Ford 7.3 gas engine replacing 6.8 v-10
https://www.popularmechanics.com/car...gas-v8-engine/
Zappo is offline   Reply With Quote
Old 08-10-2019, 06:59 AM   #2
Interesting article to be sure---thanks for sharing!
Old 08-10-2019, 07:38 AM   #3
I really wish they would share the hp/torque numbers. I haven't seen those anywhere.
Anyone seen them?
Currently vanless. Weird.
Old 08-10-2019, 07:40 AM   #4
I spoke too soon:
https://www.autoblog.com/2019/08/01/...-gas-v8-specs/
Old 08-10-2019, 09:16 AM   #5
TomsBeast's Avatar
It seems like 'going backward to go forward', keeping it simple. Cam in block pushrod engine, gasoline, not even coil on plug, it has a short plug wire so they can keep the coil away from the heat. The article says it has variable valve timing, I wonder if they got cute like Chrysler's V10, and separated the exhaust from the intake lobes, and vary both independantly.
Can you imagine being a fleet manager for a mining or power generation company, and living through owning a fleet of 6.0 Diesel F250's? Maybe Ford is trying to recapture those commercial fleet customers with what sounds like a more basic, robust power plant?
Old 08-10-2019, 11:04 AM   #6
The main reason for going pushrod is the lower operating RPMs, which helps them meet the CO2 regulations that apply to medium and heavy trucks. This is the same reason why the V10 in the F53 chassis and F450/550 were downrated in 2016. Once you start lowering your RPMs, overhead cam loses its efficiency advantage, while carrying a packaging disadvantage (which is why the E-series never got the 3-valve motors).
Reunel rear bumper
Old 08-10-2019, 08:02 PM   #7
Sboring35's Avatar
Another artificial:
The long-running E-Series cutaway will also get the 7.3-liter.
Sboring35 is offline   Reply With Quote
Old 08-10-2019, 10:03 PM   #8
Looks nothing like the LIMA engines of yesteryear. I'm curious about the head/port design.
It'd be nice if the intake is tall and narrow like the old FE high risers and the exhaust is raised like modified Cleveland heads.
But that's just me.
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
regis101 is offline   Reply With Quote
Old 08-11-2019, 05:45 AM   #9
So if the cutaways get this new engine does that mean a retrofit on a full bodied E-Series is on the horizon too?
Where's that MG Metalworks guy when we need him?
Old 08-12-2019, 08:21 AM   #10
IanF's Avatar
Packaging and simplicity. Things fleet managers love. Like back in the 90's when the police package Malibu was fitted with the 3.8 OHV V6 instead of the more powerful 3.3 OHC engine (this was after the RWD Caprice production ceased).
Personally, I wonder if/when this engine and 10 spd auto transmission will be available in crate form with a stand-alone ECM system. Could be a nice swap option for older trucks.
IanF is offline   Reply With Quote
Campervan
Joerg
BigRed4x4
BigRed4x4
