> There are two seperate levels for the extended warranty:
> Diesel EngineCARE (MSRP $1920.00)
> 13 Covered components
> All internally lubricated parts
> Turbocharger (factory installed)
> Cylinder Block
> Cylinder Head gasket
> Cylinder Heads
> Crankcase Oil Cooler
> Oil Pump EGR Cooler
> Timing Chain Cover
> Fuel Injection (high pressure oil) Pump
> Timing Chain (gears or belt)
> Fuel Injection Pressure Regulator
> Fuel Injectors
> Diesel EngineCARE Plus (MSRP $2420.00)
> 21 Covered components
> Cylinder Block
> Cylinder Heads EGR Cooler
> Oil Pump
> Fuel Injection Pump
> Timing Chain Cover
> Thermostat
> Fuel Injectors
> Water Pump
> Thermostat Housing
> Manifold (intake and exhaust)
> Flywheel
> Oil Pan
> Manifold bolts
> Valve Covers
> Seals and Gaskets (includes Cylinder Head gaskets)
> Check your local dealer for actual prices.
