Old 03-17-2010, 09:50 PM   #1
Ford (Motorcraft) "Heavy Duty" alternator-visual ID
Is there a way to tell a heavy duty alternator from a standard with a visual inspection? I went to buy one today (non Motorcraft) and the guy assured me it was the heavy duty model. I asked him how he knew this and he stated that "it had a longer warranty." Sounded like BS to me.
Thanks
Tom
Tom
Austin, Texas
1995 SMB E250
Old 03-17-2010, 10:19 PM   #2
Re: Ford (Motorcraft) "Heavy Duty" alternator-visual ID
Mine said 200 amp on the box. Don't go by "heavy duty". A heavy duty Ford alternator might be the difference between a 130 amp standard as compared to a "heavy duty" Ford 140 amp. Those are examples only.
[edit]
Mine is an MCI, purchased through Superiordc.com 209 668-2200. Don't have a clue how it stacks up against other alternators as far as quality.
Old 03-18-2010, 06:46 AM   #3
ok. Thanks
Tom
Austin, Texas
1995 SMB E250
Old 03-18-2010, 09:47 AM   #4
If it is a Ford alternator, they will all look the same. The PN is really the only way to tell them apart.
Old 03-18-2010, 06:42 PM   #5
etbadger's Avatar
The 6.0L diesel uses a small-case 6G alternator stock. Most high-output alternators will be a large-case 6G, which uses the same mount points, but the body is physically larger. The greater size allows for more windings, and less heat-generation for a given output.
Right is stock, left is a 200amp replacement:
Note that the pulley is a touch smaller as well since I wanted to have more output at idle.
-Erik
https://www.badgertrek.com - Badgers on Wheels
etbadger is offline   Reply With Quote
Old 03-18-2010, 10:04 PM   #6
Sorry, I missed the part about non-Motorcraft.
Here is where I got my high output alternator:
http://www.alternatorparts.com/6g-serie ... nator.html
Old 03-18-2010, 10:49 PM   #7
Thanks everyone. I ended up telling the mechanic to put in a "heavy duty motorcraft." I didn't specify "high output."
My bad.
It's rated at 114 amps. I don't use the house battery all that much. Really just replacing as routine maintenance as the original is 15 years old. Also may install solar down the road.
I appreciate the help.
Tom
Tom
Austin, Texas
1995 SMB E250
Old 10-22-2010, 01:11 PM   #8
For the record - these guys sold me a 250 amp alternator which has proved superb.
"DC Power Engineering Sales" <sales@dcpowerinc.com>
Hanging Out
vlamgat is offline   Reply With Quote
