Old 11-07-2009, 04:43 PM   #1
Mahukaawe's Avatar
Front differential vent tube overflowing?...
I just noticed a thin coat of oil underneath the van. It looks like it was dripping down and spraying back while driving for a while. It's not bad, just a thin coat and doesnt seem to be dripping at all while parked.
We traced it forward and up to where it seems to have originated at the top of the front diff vent tube which is all the way up on top by driver side firewall when the hood is open.
It is gear oil not engine oil and its not coming from the steering box.
Has anyone else seen this happen and could it be a result of an overfill?
Also, if I am driving in 2wd how would it overflow? Isnt the front diff gears just sitting in 2wd?
Is there something else I'm missing or should check?
I guess I could open the plug in the diff to see if it is full too.
09 E350 EB 6.0PSD SMB 4x4 kind of a 61 layout
02 F450 Flatbed 4x4 7.3 PSD
08 F150 5.4 ltr 4x4 Daily Driver
77 Orig Bronco in rebuild mode "uncut"
76 Orig Bronco rebuilt & driven weekly
71 Orig Bronco rebuilt & 4sale gots everything on it
Owned a jimmy once for about 6 months.
https://www.tropicalgardensofmaui.com
https://www.mauicabins.com
twitter @runnin6mpg
Mahukaawe is offline   Reply With Quote
Old 11-07-2009, 04:53 PM   #2
Re: Front differential vent tube overflowing?...
I'm not sure this is exactly what is happening in your situation, but I blew half the oil out of the front differential (from the top of the front pumpkin) by driving in 4WD on paved roads for about 40 miles. The front diff needs the wheels to slip on gravel or dirt surfaces, and overheats when driven on dry paved roads.
If the van is really in 2WD for the rear wheels with your front hubs unlocked your front diff should be doing nothing, and certainly not spewing oil.
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 11-08-2009, 09:24 AM   #3
LeadDoggy's Avatar
do you cross alot of rivers?
07 E350, Custom and Lifted
09 KTM EXC 530
Old 11-08-2009, 10:56 AM   #4
Mahukaawe's Avatar
No LeadDoggy, I havent had the opportunity to cross any rivers yet. Looking forward to trying one day though. The van is new and it has been in 4wd only once since picking it up.
I'm wondering if that is when the fluid leaked now since it doesnt seem to be leaking while in 2wd or parked.
twitter @runnin6mpg
Old 11-08-2009, 04:46 PM   #5
scatter's Avatar
Well, if your transfer case for the front is in neutral and the hubs unlocked, nothing in the front end should be spinning. If either one of the above is engaged and you're driving at high speed, you'll probably puke some fluid out of the breather.
I wouldn't know this from personal experiance of course....
Scatter
2007 RB50, 6.0
K1WGB
Old 11-08-2009, 05:02 PM   #6
Mahukaawe's Avatar
Gee Scatter as it turns out the "owner" of our van has just noticed that I, that is "someone" forgot to unlock the hubs......
So I guess I'll just pretend this thread never happened.
twitter @runnin6mpg
Old 11-08-2009, 06:57 PM   #7
Like Scatter I personally have never forgot to disengage my Hubs , but that will cause the very thing that you described . You should periodically engage / lock your hubs while running around town for the purpose of lubrication , just don't run at higher speeds for prolonged periods .
Greggde
