Old 06-14-2010, 01:12 PM   #11
etbadger's Avatar
Re: Front Wheel Bearings
Ok, here's my writeup with pictures. The photos are all from the reassembly as I really didn't want to get my grimy hands on the camera during dis-assembly, nor admit to how dirty everything was by that point.
http://www.badgertrek.com/sportsmobi...Bearings.shtml
Also transmission flush for those who want to do it themselves:
http://www.badgertrek.com/sportsmobi...iftFluid.shtml
As always these are for entertainment purposes only, undoubtedly I did something "wrong" and you should only ever let a certified & licensed Ford tech ever touch your van ...
-Erik
https://www.badgertrek.com - Badgers on Wheels
etbadger is offline   Reply With Quote
Old 06-14-2010, 03:06 PM   #12
Angel's Avatar
Badger,
You said to use wheel bearing grease for disk breaks. When I called Bob's Break & Alignment in Lawndale, CA (recommended on this forum) and asked them what grease they use, they said "a synthetic wheel bearing grease". Is a grease for disk breaks a synthetic grease?
I think my local mechanic can do it but I want to make sure he uses the right product. I will buy it and take it to him.
What grease-brand, weight, type-do you all think should I buy?
Angel
2000 Isuzu Rodeo V6 4WD
2006 Chalet LTW 15ft. Folding Travel Trailer 14 in. tires
Angel is offline   Reply With Quote
Old 06-15-2010, 03:40 PM   #13
stikine's Avatar
I know Red Line comes highly recommended (it is synthetic) & I have used same:
http://www.redlineoil.com/product.aspx?pid=82&pcid=17
2007 SMB White 4x4 RB50 6.0l Diesel PH, Toyo 295/70/17 M/T E
https://www.ecotonephoto.com/
stikine is offline   Reply With Quote
Old 06-17-2010, 02:32 PM   #14
Angel's Avatar
I bought the red line grease, printed out Badgers pictures and instructions and went to my repair place to have the bearings packed. My 2008 Dana 60 is not the same as Badgers. My bearings are sealed. I was told that doing a break job is easier to do on my van but when the bearing go, it will be more expensive as they have to replace the whole unit. I am learning!!!!!!
Angel
Old 06-18-2010, 07:44 AM   #15
Angel said:
I am learning!!!!!!
When I was growing up, my mother used to shout "LEARN!" anytime we were confronted with a particularly painful or expensive situation. This sounds like the latter situation.
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 06-18-2010, 12:11 PM   #16
Angel's Avatar
Hi Ed,
Since I only have 20,000 miles and the bearings are not making any noise, the learning experience was free, this time. Now I am on alert because the next learning experience is sure to cost me twice as much.
Angel
Old 06-18-2010, 03:01 PM   #17
tskyhi's Avatar
Erik,
Awesome write up and pics. I am currently replacing front bearings, ball joints, tie rods, pads, and rotors.
I don't know why, but I am having a heck of a time coming up with a source for the grease seal(#48816) and have spent far too much time on the net trying to do so. Manny, Moe, and Jack weren't much help.
I've talked to SMB and Dynatrac and was told to cross reference early Chevy K30's, but that's still a struggle. I know this should be a stupidly easy part to find. I'm starting to think I've entered the twilight zone.
Please help.....where did you source your seals, what part#, and how much? This should be a $7-10 part right?
Thanks,
Tim
Tim
2006 Ford E350 6.0 SMB 4x4 Modified EB45
tskyhi is offline   Reply With Quote
Old 06-18-2010, 03:30 PM   #18
Roonie's Avatar
Thanks,
Tim
I just did a quick google search and came up with this... Don't know the company or anything else about it, just an example.
https://www.4wdfactory.com/store/produc ... aring-Seal
edit; I too would like a source for the wheel bearings and seals as a kit if possible as I have gone to 2 local auto parts stores (Napa, O-Reilly) and they both don't carry all the parts. I am looking at repacking my bearings as well. The above link may work but I haven't done the legwork to find out yet.
Old 06-18-2010, 03:58 PM   #19
Erik,
Thanks,
Tim
Tim,
Just curious, why are having to replace all of the above items? High mileage?
I recently had my bearings re-packed and seals replaced by a local trusted 4x4 shop at 40k miles.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 06-19-2010, 08:23 AM   #20
stikine's Avatar
Just curious, looks like there is no requirement for repacking or inspection of the rear wheel bearings?
