Old 06-09-2014, 06:51 PM   #1
Gas filler Tube
Can some tell me if there is supposed to be a metal flap at the gas nozzle filler tube? I am getting an error code that there is evaporative emissions issue (P0456). Likely culprit, I suppose, is the gas cap--- but I have a separate dummy light for that.
I have a 2011 E250.
2horsegarage is offline   Reply With Quote
Old 06-10-2014, 07:56 AM   #2
Re: Gas filler Tube
I have a 2011 E250.
There is a flap on every van I've ever seen, but I haven't been around many quite as new as yours. The really new Fords I've been around (cars not vans) don't even have a gas cap anymore, just a door with a rubber seal around it, which makes very little sense to me. Is the van running fine otherwise?
Old 06-10-2014, 10:21 AM   #3
yvrr's Avatar
Re: Gas filler Tube
Before I had a Scan Gauge, I once got a Check Engine light which turned out to be cracked filler pipe where the gas cap screws on.
Jack
'01 Ford EB50p Quigley 4WD
Old 06-10-2014, 12:38 PM   #4
Re: Gas filler Tube
Van runs fine. I am going to try a new cap and see if that does it... but I feel like there should be a metal flap --- although I never really paid attention before.
Coddiwomple
Rpence
Esme
Amy V
