Old 06-23-2013, 05:33 PM   #1
Is this a Dana 70 SRW
Hi guys,
I have a 04 box van that I'm building into a camper. There is a pretty nasty little whine and slight clunk on launch from it, and I'm thinking about going 3.73 and a limited slip in the rear.
Here are photos. I found this thread through searching which is why I posted it there.
What a great forum here though, I look forward to participating!
http://www.thedieselstop.com/forums/f14 ... ost2533282
Here is a link to where I house photos for the build..
http://andreshoumatoff.smugmug.com/Cars ... -E-350-Van
dieselcruiserhead is offline   Reply With Quote
Old 06-23-2013, 07:08 PM   #2
Gnarvan's Avatar
Re: Is this a Dana 70 SRW
Welcome aboard, I can't wait to see where you're going to take this build.
I've always thought these types of rigs would make a great platform to build on. Make sure you keep us updated on your progress. Don't forget to take and post lots of
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-23-2013, 07:19 PM   #3
The Vehicle Certification label shows axle code 56. Assuming Ford doesn't change these codes year to year then you have 4.10 gears, non-limited slip Dana. Code 52 is the same but dually. My decoder ring doesn't indicate D60 or D70, hopefully someone else can tell you.
Hope this helps,
my3kids is offline   Reply With Quote
Old 06-23-2013, 09:28 PM   #4
thank you. Very odd because I had a comment from a van owner saying it doesn't look like a SRW axle and that the SRW axles have the wheel right up against the brakes normally. Very confusing. The rear width is only maybe 1-2" wider at most than the front with this setup. It came from Supreme Corporation this way.
Thanks for the comments also! I can't find my camera with a ton of pics of some of the progress including our little "Kitchen" which is mostly just a sink...
Here is the rear tire mount, ladder, and bike mount I came up with. It's on hinges so it swings open and locks closed..
Old 06-25-2013, 02:12 PM   #5
back to top -- thanks!
Old 06-25-2013, 07:36 PM   #6
Yup, that's a 70 SRW. The mid-tank cutaways got the same axle as the vans, with the hub against the rotor. The rear-tank SRW cutaways got the wide-track version.
