Old 06-18-2012, 06:13 PM   #1
Leaf Springs
Been reading what I can find and it seems that Deaver springs is what most folks seem to like. Is there any other options? Also has anyone used Dunbar Springs in Phoenix?
After a recent trip down some washboard roads from HELL, something has to change. After two of my cabinet doors fell off I decided to try the speed approach to the road. 45 plus mph worked but didn't make for a relaxing drive. I will say it handled just fine and never once wanted to shimmy off the road. However I would much rather drive slow and enjoy the sights while in the woods.
TraceyAZ
2005 Ford E-350 SMB 4x4
6.0 EB 50 floor plan. sold :(
TraceyAZ is offline   Reply With Quote
Old 06-18-2012, 08:49 PM   #2
Re: Leaf Springs
We recently replaced the springs and shocks in our 2006 with the Bettis / Rancho setup that SMB is currently using. What an improvement, the best $2500 that we've ever spent on the van.
-- gordon
gordon is offline   Reply With Quote
Old 06-19-2012, 02:04 PM   #3
Re: Leaf Springs
Thanks gorden,
Were you able to get what you needed directly from SMB? How has the ride been on washboard roads?
TraceyAZ
Old 06-19-2012, 02:28 PM   #4
Re: Leaf Springs
Subscribed.
Maybe it's normal but the front OME springs on my rig have a substantial concave upward profile, as if they are overloaded or not arched enough. The easiest thing would be to add an additional leaf to the spring pack and/or have the springs re-arched but an upgrade to a 10 or 12 leaf springpack is appealing. Deavers with remote reservoir Bilsteins appears to be a popular way to go. The downside is there may be some retro-fitting of the shock mounting locations.
2011 VW TDI Golf for hwy fun
Old 06-19-2012, 02:30 PM   #5
Tapatio's Avatar
Re: Leaf Springs
-- gordon
I'm fairly certain that SMB West uses Old Man Emu shocks and ARB custom leaf springs right now. That's what I have on my 2011 SMB.
Callsign KK6GIY
Old 06-19-2012, 03:15 PM   #6
Re: Leaf Springs
On top of the ride quallity issue the van itself has a lean to it. The passenger side has about 3/4 inch difference in height. While under the van changing oil last weekend I can see a difference in the springs from one side to the other. Nothing looks broken, just different from a point of view that there is less space from the springs to the bump stops and that the springs look like they are dearching worse on the passenger side.
TraceyAZ
Old 06-19-2012, 04:54 PM   #7
dig255's Avatar
Re: Leaf Springs
-- gordon[/quote]
I'm fairly certain that SMB West uses Old Man Emu shocks and ARB custom leaf springs right now. That's what I have on my 2011 SMB.[/quote]
I was just at SMB west to check progress on my van 6-14-12 and it had Rancho shocs on it did not see who made the springs, will check when I go this Thursday.
DIG
dig255 is offline   Reply With Quote
Old 06-19-2012, 05:48 PM   #8
Re: Leaf Springs
I thought SMB had made the move in the last year or two to a local vendor for springs with El Rancho adjustable shocks?
Old 06-19-2012, 06:31 PM   #9
BIGVANS's Avatar
Re: Leaf Springs
I heard the same thing.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-19-2012, 07:22 PM   #10
Re: Leaf Springs
I put in a call to SMB west yesterday, still no call back from them yet. It would be nice to have a direct bolt on repair for this.
TraceyAZ
