Old 03-11-2013, 08:57 PM   #1
fancypants's Avatar
Mercon vs Mercon V for power steering?
Hi all - I'm slowly learning more about the van, and figured the best way to do that is do as much as possible of the maintenance work myself. Did the oil change - piece of cake (although, admittedly, I have done that myself before on other vehicles).
Checking fluid levels on everything that I can, it seems like the power steering fluid is just below the minimum cold-fill line. However, I'm not sure what to add to top it off - Mercon or Mercon V? My 2006 V8 Gasser E350 manual says use Mercon for the power steering. I couldn't find Mercon at Napa, only Mercon V, Mercon III, and Mercon SP, as well as generic ATF fluid and "Power Steering Fluid". I've also found conflicting statements about not mixing grades, but also that Mercon V is "backwards compatible" with Mercon. Can anyone shed any light for me?
BTW, the transmission uses Mercon V...
KeVan: '06 E350 4x4 V8 "Transformer"
fancypants is offline   Reply With Quote
Old 03-11-2013, 11:05 PM   #2
Re: Mercon vs Mercon V for power steering?
Use Mercon-V.
If you have Dex-III laying around you can use that too. Dex-III is the same as Mercon. Mercon-V is essentially just a full sythetic version of Dex/Merc so if lasts longer but plain old Dex/Merc seems to work fine for the steering. Mercon SP is lower viscosity, so don't use that.
Old 03-12-2013, 01:18 AM   #3
fancypants's Avatar
I've got Mercon V around so I'll top it off with that tomorrow. Thanks carringb.
