Old 02-23-2012, 11:24 PM   #11
BajaSportsmobile's Avatar
Re: mpg help!
The greatest Aero Drag on a vehicle is under the vehicle. Our 4X4 lifted SMBs have a tremendous amount of Areo Drag under the chassis.
AgileOffRoad.com
Old 02-24-2012, 07:29 AM   #12
Re: mpg help!
Not much we can do about that though.....
Bill
NO2B
Old 02-24-2012, 10:03 AM   #13
Re: mpg help!
Bill
I don't know, depends how important it is to someone. Possibably removable ground effect air dams like the big Tractor Trailer guys use.
It is all about frontal area and moving the air around the chassis and not under it.
AgileOffRoad.com
Old 02-24-2012, 11:35 AM   #14
Re: mpg help!
I have a bully dog watchdog. It's like a scanguage. The stuff on the roof is during our trip and not normally up there. All that aside, would turbos help? Significantly? Mpg est.? Thanx guys!
racrx451 is offline   Reply With Quote
Old 02-24-2012, 11:47 AM   #15
Re: mpg help!
It is what it is. An aerodynamic brick. I'm not sure you would want to add a turbo to a gasser. Even if you could it wouldn't help mpg. More power but you know what that means.
2011 VW TDI Golf for hwy fun
Old 02-24-2012, 12:29 PM   #16
Re: mpg help!
Turbo cars can make better mileage than normally aspirated cars, mostly because they were designed to be small engines normally, then make big engine power when needed. I don't think you can add a turbo to an engine and expect anything other than more power. At best, it wouldn't hurt your mileage.
Have you done the normal things?
- Air filter (a clogged air filter will KILL mileage)
- Fresh oil
- Spark plugs and wires
- Higher air pressure in the tires
My Chevy PU gets about 10% better mileage with premium. It runs fine on regular, but the knock sensors drop the timing back to stop the knock, and that hurts power/economy. It turns out to be cheaper to run premium and get better mileage for that truck.
Old 03-04-2012, 11:33 AM   #17
Re: mpg help!
Yeah, I need to up the pressures in my tires. I know that will help. I also found out that the 1996-2000 express had an optional 6.5L turbo Detroit diesel. I'm currently looking for a used diesel of similar year to do a full swap... Im just not sure my tranny will bolt up to the diesel. Still doing the research. Anyone have any input on that?
Old 03-04-2012, 12:19 PM   #18
Re: mpg help!
I'll bet you have to swap more than the engine. How about:
- Fuel tank and lines
- Engine computer
- Wire harnesses
- Motor Mounts
- Instrument cluster
- Brake booster
- probably more
In computer controlled vehicles, it is not simple to change from gas to diesel or vice-versa.
Old 03-04-2012, 12:36 PM   #19
Re: mpg help!
It would be a nightmare and way to costly to make sense.
AgileOffRoad.com
Old 03-04-2012, 12:48 PM   #20
Re: mpg help!
I would buy a used van and swap everything over... Found one for $1500. I could do the work myself just trying to figure out if my trans would work.?
