06-18-2013, 09:46 AM
Need a diesel 6.0 mechanic in Sacramento,CA or Reno,NV area
Hi All,
Does anyone have any experience with a good mechanic who is located in Sacramento,CA or the Reno, NV areas? Desperate to find somebody good. Thanks.
06-18-2013, 01:49 PM
Re: Need a diesel 6.0 mechanic in Sacramento,CA or Reno,NV a
You know, if it were me, I would also post your question in the 6.0 forum on the Ford Truck Enthusiasts website at:
ford-trucks.com
or more specifically at:
http://www.ford-trucks.com/forums/forum107/
There are 387 people viewing the 6.0 diesel forum right now. One of them may have some suggestions. I believe that there is also a Northern Cal. chapter for the 6.0 (like there is for the 7.3) so you should probably join that chapter in addition to joining ford-trucks.com
06-18-2013, 02:01 PM
ford-trucks.com
OK...that's a great idea. Thanks for your help.
06-22-2013, 11:49 AM
Originally Posted by Fishbrain
Hi All,
Might help if you tell us whether you'll be needing a diesel or gas mechanic.
06-22-2013, 12:09 PM
Hi All,
Diesel.
06-22-2013, 07:45 PM
Herb had suggested one as I live about 90 miles away from Sac. You can look at this post:
viewtopic.php?f=39&t=10975
06-22-2013, 08:30 PM
I used one outside of Sacramento when my AC grenaded Folsom Lake Ford I think. They were fine, had no beef about the work being on a van or SMB etc. which my local good Ford does. I'd go back.
06-22-2013, 10:27 PM
Cool. Thanks everyone for the help.
