Re: Rebuild my D60 FF,or buy D70 SRW and rebuild?
Originally Posted by smoothpilot
I went the SRW Dana 70 route on Fat Gal. She routinely tows a 12,000 flat bed trailer w/ tractor. This load destroyed the original differential. It appears that the limited slip components failed first and the resulting steel bits took out the differential gears.
Yup, that's why I "love" limited slip. To make you feel a little better, that was the same explanation that Ford gave me when they paid for the rebuild of my semi-floating axle under the 7-year/100K extended warranty in 2007. Five years after I ordered the van new. Sure I towed a tandem one yard mixer loaded with ready mix a few times up Highway 50, but nothing like "routinely" towing 12,000 lbs.
Thanks for coming back and posting. My guess is that I will be keeping a look out for a full floating axle like yours some time in the future...
