Old 05-15-2013, 07:15 PM   #1
Replacing Alternator Procedure
I'm going to include an upgraded alternator in my FICM upgrade and am wondering if anyone has a link to some R/R instructions or a few hints and how hard it is to do. Thanks
Pat
(Making it a real engine one step at a time)
PatO is offline   Reply With Quote
Old 05-16-2013, 08:23 PM   #2
Re: Replacing Alternator Procedure
Myself, I thought the worst part was the belt. Other than that it wasn't too much of a problem but air tools help. Dropping the batteries might be trouble if you don't want to do it hot. Depending on the alternator make/model, the brackets might not fit. Mine worked OK but I had to grind a notch off the alternator case for it to sit flush the bottom. I also had to install a larger lug on the hot lead because the stud on the back of the alternator was larger. I didn't increase the buss wire because I really didn't add any more load, but it's something I want to do just because. While I was in there I installed heat shield around any wires that needed it. Took two of us about 3 hours but we forgot the belt wrench which made an otherwise easy job kind of a PITA.
Old 05-16-2013, 09:39 PM   #3
Never had to remove the radiator but pulled a bunch of other stuff off to get to the belt. Found that Ford had left the upper bracket off
Old 05-16-2013, 09:57 PM   #4
I don't remember...seems like we snaked in the belt.
Old 05-16-2013, 10:00 PM   #5
The only thing I removed was the metal turbo duct. I wish I had known about the locking feature on the belt tensioner. Getting the belt back on was the hardest part.
I didn't even disconnect the batteries, I just was very careful with the wiring.
Mine was easier because I didn't change the belt.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 05-16-2013, 10:06 PM   #6
I actually sent back one alternator because I would have had to dent the duct to make the alternator fit what a waste of time and money. After that I ordered from Nations.
Old 05-16-2013, 11:00 PM   #7
You might want something like this. http://www.harborfreight.com/serpentine ... 66344.html
2011 VW TDI Golf for hwy fun
Old 05-16-2013, 11:40 PM   #8
Left it at work 30 miles away
Old 05-17-2013, 05:07 PM   #9
Put in a very large unit from Premier Power Welder when I did the welder. Only issue was clearance on firewall and needed to "re-clock" the connections. This unit uses a much better industrial belt than the one stock.
carl
2010 SMB
Old 05-18-2013, 09:43 PM   #10
Thanks everyone for all the replies. It sounds like it is more than what I want to do myself. I think when it is in the shop soon for turbo, EGR & oil cooler replacements and other bullet proofing I'll just have it done then. I also peeked at it under the hood... geez it would probably take me all day. Right now I have more money than time.
Otter
Vantastic
maxx
