Old 12-17-2018, 01:33 PM   #61
nemesisnight's Avatar
Here is a pic of my old GPR from the doghouse from when I tore my engine all apart for new injectors, crossover, HPOP, IPR, etc, etc , you can see it sits directly behind the alternator (upper right) as Saline mentioned. I replaced mine even though it was fine while I had it apart with a monster one from here http://www.dieselorings.com/16-009-white-rodgers-stancor-586-902-monster-glow-plug-relay.html
nemesisnight is offline   Reply With Quote
Old 12-17-2018, 05:05 PM   #62
Bbasso's Avatar
I did the AIH delete just over 2 yrs ago and zero complaints.
Rob.
Current:
And had three other E350s...
Old 12-17-2018, 07:42 PM   #63
pod is correct, the front is the air intake heater relay not the starter relay as I originally stated.
And holy hell nemesisnight!!! That's the cleanest 7.3L valley I've ever seen!
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 12-18-2018, 06:38 PM   #64
Hmmm. So maybe the GPR isn't blown and the AIH relay is bad instead. I did not see two relays in there, so who knows which one I checked? Should the AIH relay be getting power when the key is on? I will try and test it again tomorrow.
maxswasser is offline   Reply With Quote
Old 12-18-2018, 08:00 PM   #65
Just out of curiosity, what were your opacity numbers on the CO emissions test?
I have noticed an increase in my numbers from last year's test to this year's test and will likely need to start hunting around to figure out why.
Old 12-20-2018, 05:56 PM   #66
So definitely don’t even have a gpr. Insead have a gpcm. Do these go bad? Also, when I had the key set to “on” there was no power to the aih relay. Should that be getting power for a cold startup?
Old 12-20-2018, 06:41 PM   #67
The GPCM should trigger an OBD2 code if there's a fault, as required under CARB emissions. That said.... I'm not sure it would trigger a code for an open glow-plug circuit, which can happen from both a broken wire, or an old glow plug with excess resistance.
Old 12-21-2018, 09:33 AM   #68
pod
pod's Avatar
Iirc, the AIH doesn't energize at startup, but only during extended idle at low temps.
I also believe the GPCM can have its own code (P0670 possibly), but there are also other codes in the glow plug circuitry that can be issued as carringb noted.
I have the same setup as you (with GPCM) and I'm chasing down p0671-p0678 after a cold start. I've prepped to replace GPCM (as well as UVCH and GP's) as I've heard they can go bad just like the GPR.
pod is offline   Reply With Quote
LiamMobile
Shyll
Faultine
rizzabove
