Originally Posted by j.whitbread
I think it can be worked out. The speed sensor on the van 5R110 has three wires, the truck 5R110 has two. The additional 3rd wire on the van goes to the ECU for the speedometer. But? Start adding conflicting speeds, wheel speed from the ABS: constant, transmission output shaft shaft speed reduces 22% when the OD is engaged. It confuses the transmission/ECU. It will just take someone to figure it out.
With 4.10 gears a GV OD is almost too tall geared. My idea was to lower my gears for better crawling and make up the difference at highway speeds with the OD.
The connector on the trans you tap into for the GV install is a 18 or 20 pin connector, 6.0 & V10 share the same trans right?
The ratio's on the GV is the one thing I didn't fully understand, if you take the spreadsheet and keep everything the same and just change the diff, you get a lower RPM at any given speed with a 4.10 than you do with 3.73. I've got 4.10 and it worked out to be perfect, something like 1800rpm and 85mph, perfect for the Diesel.
