Originally Posted by daveb
So I'm looking at the EGR Valve Position Measured and the EGR Valve Position Desired on the scangauge. Do these indicators help to tell if the EGR needs to be pulled/cleaned or replaced?
Is there anything on the scangauge that will help indicate a possible future sensor failure or injector failure?
If the measured value is not close to the desired value it indicates that the EGR valve is not operating correctly (sticking). The valves default position is fully closed, 0%. I don't think there are any other "desired vs actual" measures. I keep this list of 6.0 values in my van just in case I need to do some diagnostics on the road. I found it on one of the diesel forums stickies.
KO=KEY ON
LI=LOW IDLE
HI=HIGH IDLE
OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
?TXD: 07E02209CE
?RXF: 0462450906CE
?RXD: 3010
?MTH: 006401000000
?NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
?TXD: 07E02209CF
?RXF: 0462450906CF
?RXD: 3010
?MTH: 006401000000
?NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
?TXD: 07E02209D0
?RXF: 0462450906D0
?RXD: 3010
?MTH: 006401000000
?NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
?TXD: 07E022096D
?RXF: 04620509066D
?RXD: 3010
?MTH: 00647FFF0000
?NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
?TXD: 07E0221310
?RXF: 046245130610
?RXD: 3010
?MTH: 00090005F05F (00090005FFD8 alternate MTH found)
?NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
?TXD: 07E1221674
?RXF: 046205160674
?RXD: 3010
?MTH: 000100080000
?NAM: TFT
Horsepower
?TXD: 00
?RXF: 400080000000
?RXD: 0000
?MTH: 000A00240000
?NAM: HPR
Inj. Control Press. (ICP / HPOP)
?TXD: 07E0221446
?RXF: 046205140646
?RXD: 3010
?MTH: 003900640000
?NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
?TXD: 07E02216AD
?RXF: 0462451606AD
?RXD: 3010
?MTH: 004827100000
?NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
?TXD: 07E0221434
?RXF: 046285140634
?RXD: 3008
?MTH: 0DCA03E8000A
?NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Throttle Position 1 (Volts)
?TXD: 07E0220917
?RXF: 046245090617
?RXD: 3010
?MTH: 006404000000
?NAM: TP1
?Note: Voltage of the ETC Throttle Position Sensor number 1
KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1
Throttle Position 2 (Volts)
?TXD: 07E0220918
?RXF: 046245090618
?RXD: 3010
MTH: 0064040000000
?NAM: TP2
?Note: Voltage of the ETC Throttle Position Sensor number 2
KO=1.4 LI=1.4 HI=1.9 OR=1.4 - 4.1 VOLT Accelerator Pedal Track 2
Throttle Position Desired (Degrees)
?TXD: 07E022091A
?RXF: 04624509061A
?RXD: 3010
?MTH: 0064020000000
?NAM: TPD
?Note: ETC Commanded Throttle Angle, in degrees.
Throttle Position Actual (Degrees)
?TXD: 07E022093C
?RXF: 04624509063C
?RXD: 3010
?MTH: 006402000000
?NAM: TPA
?Note: The measured throttle angle from the throttle sensor inputs.
EGR Duty Cycle (Percent)
?TXD: 07E022166E
?RXF: 04620516066E
?RXD: 3010
?MTH: 006440000000
?NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
?TXD: 07E022096C
?RXF: 04620509066C
?RXD: 3010
?MTH: 00647FFF0000
?NAM: ETP
EGR Valve Position (mm)
?TXD: 07E022096A
?RXF: 04620509066A
?RXD: 3010
?MTH: 000100010000
?NAM: EVP
?Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
?TXD: 07E02209D2
?RXF: 0462050906D2
?RXD: 3010
?MTH: 00647FFF0000
?NAM: EVD
EGR Valve Position Measured (%)
?TXD: 07E02209FE
?RXF: 0462050906FE
?RXD: 3010
?MTH: 00647FFF0000
?NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
?TXD: 07E022167E
?RXF: 04620516067E
?RXD: 3010
?MTH: 000133330000
?NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
?TXD: 07E02209CD
?RXF: 0462050906CD
?RXD: 3000 (3001 alternate)
?MTH: 000100010000
?NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
?TXD: 07E02216A8
?RXF: 0462051606A8
?RXD: 3010
?MTH: 000100010000
?NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
?TXD: 07E0221127
?RXF: 046285110627
?RXD: 3008
?MTH: 003100500000
?NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI) ?
Exhaust Back Pressure
?TXD: 07E0221445
?RXF: 046285140645
?RXD: 3010
?MTH: 001D00500000
?NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Fuel Level
?TXD: 007E02216C1
?RXF: 0462451606C1
?RXD: 3010
?MTH: 000101480000
?NAM: FL
Volume Fuel Desired
?TXD: 07E0221411
?RXF: 046245140611
?RXD: 3010
?MTH: 006400100000
?NAM: VFD
Mass Fuel Desired (Milligrams Per Stroke)
?TXD: 07E0221412
?RXF: 046205140612
?RXD: 3010
?MTH: 000100100000
?NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Engine Run Time (Minutes)
?TXD: 07DF011F
?RXF: 0441051F
?RXD: 2810
?MTH: 0001003C0000
?NAM: ERT
Fan Speed Sensor (RPM)
?TXD: 07E022099F
?RXF: 04620509069F
?RXD: 3010
?MTH: 000100040000
?NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Fan Speed Sensor Duty Cycle (%)
?TXD: 07E022091F
?RXF: 04624509061F
?RXD: 3010
?MTH: 013103E80000
?NAM: FDC
Manifold Absolute Pressure (PSI) (BOOST)
?TXD: 07E0221440
?RXF: 046285140640
?RXD: 3010
?MTH: 012203200000
?NAM: PSI
MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
?With a little tweaking you can adjust this to read boost as you said.
??To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
12.7 FF81
12.8 FF80
12.9 FF7F
13.0 FF7E
13.1 FF7D
13.2 FF7C
13.3 FF7B
13.4 FF7A
13.5 FF79
13.6 FF78
13.7 FF77
13.8 FF76
13.9 FF75
??14.0 -- FF74
?14.1 -- FF73
?14.2 -- FF72
?14.3 -- FF71
?14.4 -- FF70
?14.5 -- FF6F
?14.6 -- FF6E
?14.7 -- FF6D
?14.8 -- FF6C
?14.9 -- FF6B
?15.0 -- FF6A
??So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Injector Timing Before Top Dead Center (Degrees)
?TXD: 07E02209CC
?RXF: 0462850906CC
?RXD: 3010
?MTH: 000A00400000
?NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Fuel Injector Pulse Width (Microseconds)
?TXD: 07E0221410
?RXF: 046205140610
?RXD: 3010
?MTH: 000800010000
?NAM: FPW
Gear (Transmission Gear)
?TXD: 07E12211B3
?RXF: 0462051106B3
?RXD: 3008
?MTH: 000100020000
?NAM: GER
Self explained
Vehicle Speed Sensor (MPH)
?TXD: 07E02211C1
?RXF: 0462051106C1
?RXD: 3010
?MTH: 000102000000
?NAM: VSS
Self explained
Accelerator Pedal Position (%)
?TXD: 07E02209D4
?RXF: 0462050906D4
?RXD: 3008
?MTH: 000100020000
?NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
?TXD: 07E0220200
?RXF: 046205020600
?RXD: 3008
?MTH: 000100010000
?NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
?TXD: 07E0221155
?RXF: 046245110655
?RXD: 3010
?MTH: 006433330000
?NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Net Torque into Torque Converter (Ft-Lbs)
?TXD: 07E02209CB
?RXF: 0462050906CB
?RXD: 3010
?MTH: 000100010000
?NAM: TRQ
