Old 11-11-2017, 07:24 PM   #1
Serpentine belt
Thinking it's time to change my serpentine belt on my 6.0L. After looking at it I think I'll have it done. Prices are all over for the job, if I can get anyone to do it after they look at it.
What has anyone out there paid to have it done?
Thanks
greatwhite1 is offline   Reply With Quote
Old 11-11-2017, 09:20 PM   #2
BVerhulst's Avatar
If I'm not mistaken, it's a major, major job on a PSD in a van.
Brian
2009 E-350 Lopes 55
BVerhulst is offline   Reply With Quote
Old 11-11-2017, 09:58 PM   #3
Bbasso's Avatar
I've done the belt on my 7.3 van and it takes less than 20 mins.
I've yet to do one on the 6.0 but can't imagine that it would be much harder.
Give it a valid try!
Rob.
Current:
And had three other E350s...
Old 11-12-2017, 08:26 AM   #4
I agree, but Rob, remember how 180deg the 6.0l is from anything we would assume. Reliable, no. Economical, not so much. Etc, etc.
Still, It's a belt. I'd certainly try it. If I owned a van I couldn't change a belt on in 10 minutes I think I'd be selling in a hurry.
Old 11-12-2017, 09:54 AM   #5
ShuttlePilot's Avatar
Greetings Greatwhite1,
I can't help you on price to get it done as I've done it myself but I'll offer up some things to consider which will effect the mechanics costs.
First, I have changed just the belt before with only taking the intercooler piping off. It can be done but it's a real pain. I had to extend the handle of a ratchet several feet to reach down to the tentioner and relieve the tension. This was the most difficult part.
Here's the thing about 6.0 belts. They are very similar in function to a timing belt in an overhead valve engine. They last a long time. Also like a Japanese timing belt it is a very good idea to change all the other rotating parts at the same time. So for a 6.0L that would be all three idlers, the tensioner which will come with it's idler, and at least the vacuum pump because they seem to get weaker after about 80k. If your into preventative maintenance this would be the time to upgrade the water pump to say a Bulletproof Diesel metal one. This is also the time to change the power steering pump if you really have a lot of miles on it but maybe save it for next time. Also how old or weak is your alternator. Probably the easiest to change on it's own but it's staring right at you if you've done all the other stuff. But like the P/S pump it could go longer if your just not in the mood.
My recommendation is take one of two paths. If your just going to change the belt because your van doesn't have very many miles on it (less than 90k miles) but it's 10 years old and original. AKA the belt is old but the pulleys haven't spun much. That can be done without taking much apart. OR If your have say 80-90k miles on everything replace the items mentioned above as you will (or your mechanic will) be taking everything off between the A/C condenser and the front of the engine. Then, like the Honda with a new timing belt, be good for another 90k miles or 9 years.
When your getting estimates from mechanics to do this job be aware of what the mechanic is replacing as that will greatly effect the prices. Example, just the belt vs, and the idlers vs, and the other stuff.
Lastly, insist on name brand parts. Gates, Motocraft, Denso, ect. Don't let a mechanic use Dorman or no name parts. Parts are cheap compared to labor and tow trucks.
Because #6.0Life
-Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 11-12-2017, 05:51 PM   #6
Bbasso's Avatar
E, I've done some work on those 6.Ohno and while it's hard compared to the 7.3, with basic tools, info and common sense most people who are mechanical inclined can diy on those motors.
And yes try to get the maintenance done now while you can- as mentioned by Shuttlepilot.
Rob.
Current:
