Old 03-30-2013, 05:53 PM   #1
twogone's Avatar
Shoutout to Ujoint
My van goes from basically empty to totally loaded... lumber and tools up to the windows... and back, quite often.
Back when I first started freshening, I asked Chris at Ujoint Offroad to send me a rear spring pack at OEM spec + 500#. All that works just fine through camping-loading and a bit more, but at maximum work-loading, I get a rear sag.
I called Chris and ordered the Ujoint Airbag setup. It is cutting edge, in that the bag is not attached to the lower mount, so axle-travel doesn't tear the bag. Brilliant!
Well, my van doesn't have enough lift (Quigley 4") to accommodate that setup, and in the attempt-to-install phase, the bags got a bit "shopworn"... little stuff, like welding tacks, etc.
I called cryin' to Chris that my new toy didn't fit, he conversed with Ray (the installer) in that way that only geniuses can, and told us to return 'em for a full refund... a full refund.
That, fellas, is an example of professionalism! Shoutout to Chris!
epilogue: Ray built a custom mount for some Firestone airbags, and they work just great... and my airbag-tearing risk is low
'95 SMB E350 Quigley 7.3
http://www.taylorarts.com
Old 03-31-2013, 08:17 AM   #2
UJOINT's Avatar
Re: Shoutout to Ujoint
Thanks! Sorry they didn't work. We'll get ya next time!
Chris Steuber
02 E350 7.3 (V4)
05 E350 V10 (V7)
17 Focus RS,90 SHO,49 Willy CJ2A
ujointoffroad.com
Old 03-31-2013, 09:24 PM   #3
Tell me about this tearing. I'm buying REF's old bags when he gets back...
and then
everything changed
Old 04-01-2013, 08:36 AM   #4
twogone's Avatar
Kim ain't gonna let you drive the young'uns anywhere that you might risk an airbag tear
The answer to your question is... if you drop a rear wheel fully into free space, you risk tearing the airbag, as it is attached at top and bottom. Ray sez I should caution any shops I use to lift the van on a drive-on vs. frame lift, or make provisions to prevent full extension. Ujoint makes a bag that does not attach at the bottom, but lands back into a receiver plate on return. I'm sure he can tell you much more about it.
The good news is, you still have shocks and springs if you tear a bag. Unless.....
Old 04-01-2013, 11:02 AM   #5
On some vehicles the shocks limit travel enough to prevent stretching the air bags, others get limit straps, others get torn airbags.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 04-01-2013, 01:45 PM   #6
When I read this, I jumpped over to U-joints site. I wonder if he'll just sell the landing plates? What did you build Marc?
Old 04-01-2013, 02:32 PM   #7
Hmmm. My airbags haven't torn from overextension, but I'm not sure if the shocks limit travel or the airbags do. I have the Firestone sportrites which are tapered, so they have about 12" of total travel which is I think is pretty close to what the shocks have. The van has been on lifts no problem, and it's been jumped several times. Come to think of it, I did have one tear jumping the van, but it was because the baseplate bolts snapped and allowed the baseplate to shift out of alignment, and it basically caused a pinch-flat a few miles down the road. This has happened twice, but only once from a jump. Firestone sent me a whole new setup, including an improved base-plate which I have not installed yet because I will need to modify them slightly. So far I'm using the original style (also sent by Firestone).
Chris - Any concerns with the airbags sliding off your landing plate? Seem like during a hard landing with some throttle, the axle is going to twist rearward pretty good. Gould that make the airbag slide off and get pinched? Do yours have in internal bumpstop? I had some under-frame Airlift bags previously, and even with 100 PSI I could still bottom them out sometimes. This was part of the reason I switched to the outboard mounted firestones.... They allowed me to re-inall my bumpstops.
Old 04-01-2013, 04:04 PM   #8
twogone's Avatar
Ujoint set up was too big for my rig by the thickness of the landing plate only. I have a Quigley lift and 4wd, but the lift block itself is 3", so I don't know if I have a nominal "... on Quigley 4" lift..." or an actual 3" lift.
Ray cut off the bumpstops, (which looked absolutely unbumped to both of us) and built up a mount to make a really perfected fit to my rig. I haven't run 'em loaded yet, but he put in 50#'s as a start, and it picked up the rear 1 1/2". Really tightened up the ride, but again, haven't run loaded.
I'll try to get a camera out and make a film about Round 3 of the remodel which will include the bags and particularly the Ray Mount, but I gotta dig out from all these bills first.
Old 04-01-2013, 07:07 PM   #9
I'm just trying to figure out what keeps the bottom on target when they come down. The U-Joint kits bottom plate doesn't look much different than mine.
Old 04-01-2013, 07:55 PM   #10
UJOINT's Avatar
I ran this setup on Vanaconda for a few years, honestly it was out out lazyness! When I first installed my bags years ago I ran a limit strap to keep them from over extending. When I went wheeling to shoot a video I unbolted the bottom mount for more articulation. Never hooked them back up and they worked fine for 2 years and many many miles.
The axle doesn't move enough front/rear to have the bag come off the pad. I tried to find a good long travel bag and there are a few out there, but nothing that I liked. My kit has to have a lift spring to clear everything.
Chris Steuber
02 E350 7.3 (V4)
05 E350 V10 (V7)
ujointoffroad.com
