Old 08-15-2016, 10:08 PM   #11
MadScience's Avatar
I recently put a Dakota SGI-5E in, and it has different types of inputs and outputs, using the wrong ones resulted in behavior not entirely unlike what you described. (I don't recall exactly, I just couldn't get anywhere reasonable until I figured that out.) This made me wonder if the unit you have (which seems to have a single input and output) works correctly with the van.
A bit of searching found a reference to Quadvan using it, but connecting it to the ABS sensor on the rear differential. -- That might at least be a clue, or if something on the transmission is indeed botched, a workaround.
Keep in mind that if you do take the speed reading from behind the transfer case, that you'll get correct speed and distance in low range, but the transmission will have to be shifted manually. Well, I suppose it'll eventually shift, at some stupid high RPM. This isn't a huge deal, since those transmissions will stay in a gear you select (won't shift into first if you select second.)
Old 08-22-2016, 08:20 AM   #12
Thank you to all who offered ideas, The problem is SOLVED.
As it was pointed out, the 18 tooth tone ring that was installed during the conversion replaces a output shaft gear driven pickup that had 3 teeth. therefore the VSS was going crazy due to receiving too many pulses. BajaSportsmobile from AgileOffroad.com clearly explained this to me. He really knows his stuff. He suggested that we remove all but 3 teeth from the tone ring. So we removed 5 teeth, leaving 1 tooth, removed 5 and so on until we had only 3 teeth on the ring. (see post from MadScience).
Thanks again, the forum is a great resource.
wr2nxt is offline   Reply With Quote
Old 08-22-2016, 08:32 AM   #13
BajaSportsmobile's Avatar
Glad to have helped, and hear that it all worked out.
AgileOffRoad.com
Tags
speedometer
