Old 01-20-2015, 04:14 PM   #1
cmyoung's Avatar
Sportsmobile E350 6.0 diesel won't shift
Help! Van is stuck at a friends house and won't shift. It starts normally and the shifter moves through the gears but they won't engage. When the shifter is moved back into Park there is some grinding. It was last run 4 days ago and drove from San Diego to LA with no problems.
2006 E350 R/B 4wd, Sportsmobile suspension, 6.0 Powerstroke diesel
cmyoung is offline   Reply With Quote
Old 01-20-2015, 04:31 PM   #2
Re: Sportsmobile E350 6.0 diesel won't shift
Transfer case probably got bumper into neutral. The grinding means the output shaft is spinning when you put it in park.
Old 01-20-2015, 04:32 PM   #3
Originally Posted by carringb
Transfer case probably got bumper into neutral. The grinding means the driveshaft is spinning when you put it in park.
Been there, done that (on multiple vehicles).
Old 01-20-2015, 06:19 PM   #4
cmyoung's Avatar
Duh! That makes perfect sense. I had been sleeping in the van for 4 days and could have easily bumped the shifter. Unfortunately I had to abandon Clifford (big red van) and won't be able to confirm it for 5 days. Thanks.
