Old 09-25-2016, 08:31 PM   #1
Torqshift
Anyone know how to tell in the vin if a van has torqshift? Did all 2005+ E350's w/ the 6.8 have torqshift?
Thanks!
Taylor3633 is offline   Reply With Quote
Old 09-25-2016, 10:33 PM   #2
deserteagle56's Avatar
Thanks!
I believe that's correct. If it has the V-10 it also will have the Torqshift.
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 09-26-2016, 06:23 AM   #3
The quickest and easiest way is an overdrive button on the end of the shifter vs. the tow/haul button. I may have this backwards but I'm almost positive the 4r100 will have an tow/haul and a torqshift will have an OD on/off on the end of the shifter. Past that you'll actually have to read, research and all that stuff.
Old 09-26-2016, 08:33 AM   #4
Definitely backwards, and also sometimes wrong
Gas engines with the TorqueShift (V10 for vans, also the V8 in some cutaways) have Tow/Haul mode with the TorqueShift.
6.0 PowerStroke vans all have the TorqueShift, but retained the OD-OFF light from the 4R100.
A better way to tell is just look for the "3". TorqueShift vans all have a shifter labelled "PRND321" except the new 6-speeds which get "PRND421". 4-speed vans have the traditional "PRND21"shifter
Old 09-26-2016, 08:43 AM   #5
Annie O's Avatar
TorqShift: that would be a good name for a pit bull!
My 2011 V10 TorqShift has PNRD321 + tow symbol/button on end of shifter.
2011 V10 E350 XLT SD Quigley/AOR (RIP'd)
Annie O is offline   Reply With Quote
Old 09-26-2016, 01:33 PM   #6
Ah, thanks for the correction! That's great info to know. Hopefully I didn't confuse anyone worse.
Hercules
firedude67
TBD
thatsandrea
