Old 02-22-2012, 11:30 AM   #1
rionapo's Avatar
Tow/haul vs. downshifting
First impressions of this fancy new (to me) thing called tow/haul: it seems okay for long and gentle grades but doesn't work on curving, steep or steepish mountain roads. It seems to require too much braking for my tastes and its downshift from 3rd to 2nd kicks the rpm up towards 3k on my v10. Or do I find myself reverting to downshifting because I haven't used tow/haul enough to understand it? I also haven't seen it upshift though that, too, may be from lack of practice. As discussed in some other threads, downshifting lets you drop into a lower gear and cruise and I haven't experienced it in tow/haul. (Maybe it's like converting to automatic transmissions????)
-Don-
“Often bumpy roads lead to beautiful places. And this is a beautiful place.”
— Dave Martínez
rionapo is offline   Reply With Quote
Old 02-22-2012, 11:59 AM   #2
Viejo's Avatar
Re: Tow/haul vs. downshifting
Please pardon my ignorance, but WTF is Tow/haul?
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 02-22-2012, 12:35 PM   #3
rionapo's Avatar
It's a gear ratio adjustment on newer (I presume) Fords that uses the transmission to slow the vans on downhills.
-Don-
— Dave Martínez
Old 02-22-2012, 01:23 PM   #4
And it will change the upshift points so the trans doesn't 'hunt' between gears, and so it has enough rpm's to pull hills.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 02-22-2012, 03:02 PM   #5
Advanturetrek's Avatar
My manual (2011 E-350 w/ TorqShift) says (paraphrased) that tow/haul has the following effects:
1. Shift points will occur at higher vehicle speeds
2. The torque converter will lock up at lower speeds
3. Upshifts are delayed during hill cresting
4. Engine braking is provided without moving the selector lever
5. Manual 1, 2, and 3 still available
6. Automatic "grade braking downshift"
The Yeti: SMB 4x4 Ford EB, super camper top, RVI interior build
http://www.advanturetrek.com
http://www.facebook.com/AdvantureTrek
Advanturetrek is offline   Reply With Quote
Old 02-22-2012, 03:13 PM   #6
Sounds like a good way to control transmission heat buildup.
Old 02-22-2012, 05:05 PM   #7
rionapo's Avatar
All of which is consistent with my experience. I just seem to take greater comfort in winding and steepish mountain roads using the manual gears where I can lock in a speed and roll down the hill. Tow/haul seems to gain speed between turns, causing too much braking, IMO. I guess I'm wondering if I'm not giving it enough of an opportunity.
-Don-
— Dave Martínez
Old 02-22-2012, 05:42 PM   #8
Viejo's Avatar
Sounds great - I want one. I mean - I want one of what the manual promises, not one of what rionapo seems to have.
2002 E350 7.3 PSD
Old 02-22-2012, 08:29 PM   #9
SMoaB's Avatar
I don't understand what it is. Hardware, software? Google didn't help to much
http://www.towhaul.com/
SMoaB is offline   Reply With Quote
Old 02-22-2012, 08:35 PM   #10
Tow/Haul is a control on the end of the transmission lever stalk. Believe it was only available on the V10's in the vans. Diesels had the overdrive deselect on the end of the transmission stalk.
