Old 04-13-2012, 10:10 AM   #1
V10 fuel question
A while back, I was searching for performance mods on the V10 to milk a few extra MPG, and ran across a thread discussing a certain part that fails on the v10 like clockwork every "Xthousand" miles. I thought it was every 50k miles, but I don't remember. From my understanding it was an easy fix and seemed to be electrical? Can anyone point me to the part or thread? I have been looking and looking to try and find it again.
Best,
C.
c7train is offline   Reply With Quote
Old 04-14-2012, 12:36 AM   #2
BIGVANS's Avatar
Re: V10 fuel question
My V10 has well over 100K - No problems, I would also like to know about any failures.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 04-14-2012, 01:01 AM   #3
Starter relay. It's on the fender by the battery. It's about $12 for a cheap one, or ~$22 for a OE one. Bumping the ignition will usually make it go eventually, and if that doesn't work the terminals can be jumped with a leatherman. (Make sure its in park! it overrides the safety switch doing this)
Old 04-18-2012, 12:59 PM   #4
Thanks!
Old 04-18-2012, 06:04 PM   #5
V10 fuel question
CarringB, the starter relay would affect mpg? I have a 5.4 but am still curious.
Thx
Currently vanless. Weird.
Old 04-18-2012, 06:30 PM   #6
Thx
In a word: NO.
If it failed, and you couldn't start your van, it could reduce your fuel consumption however.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 04-18-2012, 08:18 PM   #7
Ah, thanks, I think i'm seeing the pattern here.
Old 04-20-2012, 03:26 PM   #8
What is bumping the ignition?
Pete is offline   Reply With Quote
Old 04-20-2012, 06:48 PM   #9
Turning the key to the START position. Repeat until the solenoid engages the starter.
6.0 PSD 4.10 Posi
2015 VW GTI
Leaving CA for WA
Old 04-20-2012, 06:59 PM   #10
I have had two vans with the v-10's. No problems at all. I have been very happy with both. My first van had 177K on it when I sold it. It ran solid the entire time with no problems. Have 68K on my current one and it been bullet proof..
kre7277 is offline   Reply With Quote
