Old 12-28-2011, 11:33 AM   #1
wandering
I have a 91 Ford E250 RB Sportmobile. I replaced the steering box 5 years ago,(about 50,000 mi) which improved the wandering alot. The van has started wandering more lately. I travel to Baja in the winters and carry 2 kayaks weighing about 150lbs more or less, so I know that weight up high can't help. I drive bad roads alot and am amazed at what those van can do. I looked at the steering box and it has about 1/16" play where the shaft exits the box. I bought another rebuilt box and right on the end of the shaft they had a label that said the shaft will have lateral movement and will not be the cause of wandering., so I returned it. Anybody no if 1/16" is too much? The van doesn't wander badly but I would like it to be the best possible, to make driving easier and safer. I put a helwig rear stabalizer bar on this year, which I like for sway. I run 60-70 psi and weigh in at 7100lbs. Thanks for any input, Lance
Lance is offline   Reply With Quote
Old 12-28-2011, 12:09 PM   #2
dhally's Avatar
Re: wandering
Here's a little info
2009 E250 RB 5.4L "SilVan"
Old 12-28-2011, 02:57 PM   #3
Re: wandering
thanks for the info on the info, I am curious about those steering stabilizers. Also I didn't mention that the steering wheel has alittle free play, which sounds like a steering box issue to me.
Old 12-28-2011, 11:32 PM   #4
Re: wandering
Because of the miles, I would also tighten the steering box to reduce the play. Also, the front end is probably due for a thorough go-over (ball joints etc).
Old 12-29-2011, 11:09 AM   #5
Re: wandering
thanks for the imput, I thought those steering boxes were not adjustable. going to frontend shop in Eugene for a checkup, they specialize in trucks and RVs, will pass on your thoughts.
Old 12-29-2011, 06:36 PM   #6
Re: wandering
just back from checkup, radius rod bushings are bad. they say that could be a big part of my problem. steering box is a little loose and they will tighten it. my van has a spring sag in the rear to the drivers side and lower in back than front. they can re-arch the springs, not sure I want to spend the bucks on that but read on forum it could improve handling?
Old 12-29-2011, 08:36 PM   #7
Re: wandering
I would skip the re-arching. They usually return back to a sagging condition.
Check with Benz Springs in Portland. They are a manufacturer, and will make anything you want. They are pretty inexpensive. Many of the trucking companies on the West Coast use them.
Old 12-29-2011, 09:32 PM   #8
vandiesel's Avatar
wandering
Can benz spring make a similar setup to a deaver?
Old 12-29-2011, 11:11 PM   #9
Re: wandering
Looks like they have some 14-leaf springs for sale! Might be a little overkill for a van though
http://www.benzspring.com/garage/peterbilt/
Seriously though, I have thought about heading over to get a quote a Deaver-like setup. I can't imagine they wouldn't, but I also haven't ask so I don't really know. The one time I was over there was to pickup some F650 front springs, and I was in a rush so I didn't take the time to ask.
Old 12-29-2011, 11:14 PM   #10
Re: wandering
This is neat:
http://www.benzspring.com/process/
